Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    2
    Benton, KY
    2007 New Holland TC30
    Default 2007 New Holland TC30 Oil and filters?
    I've got a 2007 New Holland TC30 that has a frame mounted back hoe and front end loader. I'm located in western Kentucky, and I am not sure what I need to do maintenance wise. If some one could tell me what oil and filters I need to change, I would greatly appreciate it. I've had it for a couple of years and it has 150 hours on it. I need to know what to buy, brands etc if some one is willing to take a few minutes. What all should I do? Oil, fuel, hydraulics, grease etc? My manuals are in storage, lost until who knows when. Just a quick list of filters, grease, and oils would be helpful. Thanks Patrick.
  2. #2
    Join Date
    Apr 2007
    Posts
    724
    Northern Lower Michigan
    Kubota B3030HSDC
    Default Re: 2007 New Holland TC30 Oil and filters?
    Welcome!
    oil-any 15W40 motor oil will be fine-diesel rated,Shell Rotella is very popular.
    oil filter-Carquest 85348,Wix 51348-very common
    If you have the hydrostatic transmission,the service interval is first change with filter at 50 hours,about 8 gallons,every 600 hours after.
    grease-moly-disulfied black grease is an excellant low cost choice.
    More questions?Post back or post the questions on the New Holland owning and Operating Forum.
    Good Luck!
  3. #3
    New Member
    Join Date
    May 2013
    Posts
    2
    Benton, KY
    Thank you for your response. I guess I have some other questions. A mod could move this to the New Holland Operating forum if needed. Otherwise, I will finish this thread and post there in the future.
    1. What do I need to do for a manual transmission?
    2. What kind of hydraulic fluid and filter to use?
    3. Do I just hit every grease fitting, or are there any I should avoid?
    4. Are there any issues I need to be warned about with this tractor?
    I dont think anything has been done to the tractor.
  4. #4
    Join Date
    Apr 2007
    Posts
    724
    Kubota B3030HSDC
    Your tractor will use the same fluid for the transmission,hydraulics,and final drive.Universal Tractor Fluid(UTF)meeting the Ford/New Holland 134 spec such as New Holland Ambra-very common.
    Hydraulic filter-Carquest 84098 or equiv.
    The loader and backhoe should be greased every 10 hours,or so.The tractor itself a little less often.
    Your TC30,used to be a Ford 1610?,Shibauru unit made for decades-good basic unit.
    Even though you can't locate you operators manual,you really need to obtain one.It will give fluid capacities,drain and refill instructions,etc.Maybe 20 bucks at a dealer or online.
    Once again,unleash your questions on the New Holland forum for much better answer answers than I can provide,and most likely more than you care to read,Good Luck!
  5. #5
    New Member
    Join Date
    May 2012
    Posts
    3
    Louisburg, MO
    New Holland TC30
    When I bought mine the dealer said 30wt oil was fine in the hydralics
Similar Threads
  1. Worn Out New Holland TC30
    By kencharba in forum New Holland Owning/Operating
    Last Post: 08-08-2013, 09:41 AM
  2. 2002 TC30 filters
    By Maka in forum New Holland Owning/Operating
    Last Post: 08-24-2010, 12:32 PM
  3. New Holland TC30
    By Hoosier Hay Man in forum New Holland Buying/Pricing
    Last Post: 06-11-2009, 12:16 AM
  4. New Holland TC30
    By jand38 in forum New Holland Owning/Operating
    Last Post: 11-08-2007, 03:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
