Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Join Date
    Mar 2013
    Posts
    163
    Harrisburg, PA
    New Holland TC45DA
    Default I need a grease gun that won't leak or ooze oil
    Nothing too expensive I hope, just a manual grease gun should do.
    I had one before I owned the tractor and it would ooze oil anytime I stored it. Grease is designed to stay put and is easily sealed with o-rings so even though it felt heavy and solid I suppose it was cheap?
    David
  2. #2
  3. #3
    Join Date
    Mar 2013
    Posts
    163
    Harrisburg, PA
    New Holland TC45DA
    Default Re: I need a grease gun that won't leak or ooze oil
    I saw that one listed in another old thread about grease guns. Does it keep relatively tidy?
    David
  4. #4
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Yes. But it is a grease gun after all
    It doesnt ooze or leak when you pump it or store it if thats what you mean.
    The type of grease used can make a difference too. Some grease really sheds oil in the summer heat, while others hold their oils in suspension just fine, others act like lard on a stove and go right to a liquid state. A grease gun's seals are designed for thick grease not thin oil and even the best gun can leak oil out the tube if the weather gets hot enough and the grease releases it s oil. Better quality grease usually doesnt go as oily as the cheap stuff.
    What type of grease are you using? I usually use this Lubex EP Gr.2 :Irving Quality Lubricants & Specialty Fluids :: Grease Bearings Its not that expensive, nor is it some fancy "boutique" grease made by a specialty refiner, but is a decent grease used by probably 60% (likely even more) of the heavy equipment operators in this area.
  5. #5
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    2,175
    W. Central Louisiana
    JD 5083E; JD 5085M; NH TN70A; Ford 2600
    I use the pistol grip gun from JD. I think it runs about $25-30. I have two of them and I've used them for years.
    I need a grease gun that won't leak or ooze oil-grease_gun_480606-jpg
    '12 JD 5083E Cab MFWD FEL
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    Vermeer 504R round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Krone 5.52 Tedder; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '01 Peterbilt 379.
    "I've come to the point in my life where I can't remember if I've lost my horse or just found a rope."
  6. #6
    Join Date
    Mar 2013
    Posts
    163
    Harrisburg, PA
    New Holland TC45DA
    I've got a couple of tubes of Mobilith SHC 460 that would seep oil from the old grease gun. Once those are gone I'm not sure what I'll buy.
    David
  7. #7
    Gold Member
    Join Date
    Nov 2011
    Posts
    496
    Enid, OK
    2012 John Deere 3720 eHydro
    The current unit I have doesn't leak/ooze now with the stuff JD sells but when I was running a synthetic grease I purchased at Attwood's it separated and what remained congealed and was worthless. What kind of grease are you using. You might get some helpful opinions...or it end up like a motor oil question.
  8. #8
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,461
    Oklahoma
    JD cut
    There was a good article on grease at
    Machinery Lubrication Magazine
    Here it is:
    Storing Grease to Avoid Bleed and Separation
    This magazine is geared mainly for industry, but lubrication is lubrication.
  9. #9
    Veteran Member jimgerken's Avatar
    Join Date
    Nov 2001
    Posts
    1,638
    Minnesota
    John Deere 3720
    If you want an inexpensive one, I cannot help. If you can afford the Milwaukee M12 battery operated gun, you will not be disapointed. I bought one a couple years ago when they had a great trade-in offer, so the price seemed reasonable. I was also already using these M12 batteries so that helped sell me.
    The gun has not leaked or oozed any oil or grease since I bought it. It has shot about ten tubes of grease. The M12 lithium ion batteries are amazing, the first charge lasted a year of greasing, including one day of six tubes shot into a field disk I brought home. If this gun is in your budget, you will love it.
  10. #10
    New Member
    Join Date
    Jun 2013
    Posts
    21
    Gainesville
    John Deere 1998 770
    Lots of good points on grease above, but consider this. Some grease is designed to "bleed". they work well in sealed bearings. Some are not, they work well in pin joints. Grease is a combination of an oil (wich can have a thick or thin viscosity) and a "soap" base. The base is normally lithium, most common, or calcium for higher temps. Sometime other additives are added like graphite or moly. For sealed bearings a #1 consistancy grease should be used. For not well sealed bearings a #2 with a heavier base oil should be used. For pin joints a #2 or 3 with a heavy base oil and possibly graphite or moly.
    OK, so now how do I get by with one grease ? If you are running heavy equipment a lot, you don't. Use the right grease for the right part. For me running a JD on a part time basis and some other small equipment, I use a #2 grease recommended for auto chasis lube. (today these greases provide excellent lubrication in lots of applications). If you use this for pin joints, grease often.
    Even a good grease gun will bleed some greases through the nozel, especially in warm weather. The most important consideration is how much pressure can the gun produce to free up and clean up tough joints. A lever gun is better than a pistol grip and should put out 3-5,000 psi. (You can check with a grease fitting attached to a pressure gage.)
Similar Threads
  1. Oil leak on mf135
    By ts1986 in forum Massey Ferguson Classic/Vintage
    Last Post: 06-06-2013, 02:54 PM
  2. John Deere x728 oil leak
    By rubadub in forum John Deere Lawn & Garden
    Last Post: 06-03-2013, 10:54 PM
  3. oil leak
    By allen6634 in forum Ford Vintage Tractors
    Last Post: 05-28-2013, 06:08 PM
  4. Oil & Fuel Iseki TM3240 Oil Leak
    By avtar412 in forum Iseki
    Last Post: 05-07-2013, 05:34 AM
  5. Charger For Lincoln Grease Gun
    By Harold_J in forum Parts/Repairs
    Last Post: 04-23-2013, 11:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
