Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Veteran Member Happy Gilmore's Avatar
    Join Date
    Jan 2014
    Posts
    1,685
    Southeastern, MA
    Ford 5610 Ford 4630 Ford 3930 MFWD w/ 7310 loader Ford 3930 Kubota BX1500 Kubota RTV 900XT Kubota F2680E 72"RD
    Default 5 gallon pail of oil, need pump recommendations
    I'm looking to get a lever style pump of good quality for dispensing oil from 5 gallon pails. I have a simple plunger style currently which I'm not thrilled with. Any thoughts
  2. #2
    Veteran Member big bubba's Avatar
    Join Date
    Mar 2007
    Posts
    1,303
    arkansas
    m8540
    Default Re: 5 gallon pail of oil, need pump recommendations
    Quote Originally Posted by Happy Gilmore View Post
    been real pleased with this esp for hyd oil change
    Ironton Lever-Type Oil Pump 5-Gallon | Barrel Hand Pumps| Northern Tool + Equipment
  3. #3
    Join Date
    Dec 2013
    Posts
    2,063
    Southern Alberta, Canada
    4410 and F-935 John Deere, MF 245
    Debated whether to post this or not. I don't pump my oil as the arthritis in my shoulders just makes it too much of a pain. I use a 20 lb propane tank with a 3/4" pipe brazed in that goes down to the bottom of the tank. That pipe has a hose with a valve on it that lets me control the flow of the oil. The valve also has a short piece of 1/2" copper pipe on the other end so that I can put the oil in where I want it. The tank also has a 1 1/2" close nipple brazed in that has a 1/4 turn ball valve on it so that I can pour oil into the propane tank. I also installed a pressure gauge (optional), a safety relief (not optional) and an air fill valve for an air chuck. It makes adding oil to a differential under a vehicle very easy. This idea can easily become very dangerous which is why I have a pressure relief valve. 60 lbs air pressure is plenty to move oil around. If you do build something like this take a moment to test the safety of your work. Fill the tank with water and close it all up with a grease zerk and a pressure gauge. Test to at least 100 lbs pressure with a grease gun. Happy oiling!
  4. #4
    Veteran Member Dozernut's Avatar
    Join Date
    Apr 2002
    Posts
    1,584
    South Eastern Illinois
    M5660SU, ZD21, RTV900, B2630
    Take a look at this, I have one and it works great. Manual Lever Oil Transfer Pump - Tractor Supply Co.
    Sorry big bubba beat me to the punch I didn't open his attachment . His looks lower in price, but the TSC one does include the bucket.
    RB
  5. #5
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,766
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I think my pump arm would wear out pumping 2 oz of oil per stroke with that. OK if just putting in oil to a rear differential, or a quart or so, but to put in a 5 gallon can full would take a while.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  6. #6
    Join Date
    Mar 2007
    Posts
    1,303
    arkansas
    m8540
    Quote Originally Posted by Gary Fowler View Post
    hey know what you mean...try 3x 5 gal for hyd change on the tractor! but....much less mess & chance for contaminates than other more primitive methods i've used. works great for ft axle & changing gear oil in all my vehicles.
  7. #7
    Join Date
    Jan 2014
    Posts
    1,685
    Southeastern, MA
    Quote Originally Posted by Dozernut View Post
    I recently picked this one up at TSC. Got a fresh bucket of Super UDT2 to test the pump on.
  8. #8
    Join Date
    Jan 2014
    Posts
    1,685
    Southeastern, MA
    Tried out the pump today doing an oil change on the Ford 4630. I have to say it works pretty well. I ended up buying a second one for the Super UDT 2
  9. #9
    Join Date
    Jan 2014
    Posts
    1,685
    Southeastern, MA
    Well I used the second pump today, decided to do the hydrostatic fluid in the BX1500, did the engine oil while I was at it. Since I was having so much fun with the new pumps, I did the engine oil in the 3930 2wd. Need to get another 5 gallon pail of 10W30 and the 5610 will be next. Pumps work great, definately makes the oil changes a lot easier. I'm thinking a third pump will be in the future for the NH hydraulic oil. I've got 3 tractors due for hydraulic oil changes, 40 odd gallons, can't wait maybe a drum of hydraulic oil should be in my future
  10. #10
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    not sure were i picked it up at.... it is a pump, that attaches to a wired/or cordless drill. has garden hose ends on both sides of it. rated for water, oils, diesel, (not regular gas).
    also have a couple "hand siphon pumps" toss 5 gallon can of gas up on tractor, stick long hard tube down in can, then stick flex hose down in gas can on tractor, turn a little nob on top and a couple squeezes to start siphon and away it goes. same thing for 5 gallon bucket of oil. i only remember them for use in the old kerosone heaters used as extra heat in the winter, and fueling them up. till a few years back, and now use them for generator, and tractor, and dumping gas into a vehicle if need be.
    my issue with the 2 hand lever pumps the others linked to, is they sputter and spit and drip oil during use. and a slight bump and hose falls out. granted always better than dealing with a variety of funnels and have an assortment at that, for what funnel works better without flipping over and spilling.
    i might have to check to see if a sprayer pump (for spraying weeds and/or the lawn) can handle oils. more so the pumps with electronic pressure switch for use of a hand wand. for pressure on demand. 12v battery with a battery minder/charger hhmmsss....
    Ryan
Similar Threads
  1. Replies: 30
    Last Post: 01-22-2018, 10:56 AM
  2. PTO pump, lake to 200 gallon plus container
    By boggen in forum Build-It Yourself
    Last Post: 05-26-2012, 10:43 PM
  3. Oil & Fuel 5 Gal. hyd. oil pail pump...US and Canada?
    By B58Hustler in forum John Deere Owning/Operating
    Last Post: 01-01-2012, 10:12 PM
  4. 5 gallon manual pump
    By johnnylight in forum Oil, Fuel & Lubricants
    Last Post: 04-17-2007, 10:36 PM
  5. 12v water pump to 55 gallon drum
    By goodoleboy in forum Rural Living
    Last Post: 04-06-2005, 02:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
