southernbound
Hi folks- I've searched but get confused on this subject. I obviously need to drain my diff fluid/trans.lol. The boot over shifter was off. Hopefully thats were the moisture is coming from.
My question is..Manual calls for 80-90 gear oil.. Alot of ppl run same type of hydro fluid in both.. I want to do this as well. Is the travellers premium universal stuff rated to replace case hytran a good substitute? I really dont wanna go cheap, it's just the closest IH case dealer is 1.5 hrs.
That being said..This is my house tractor. It's barely used. If it snows, I'm pushing a 2 car driveway, light lanscaping/digging holes. Currently getting ready to build a pole barn so this tractor will be getting used a bit...I just want a good substitute to put into trans/diff.
The reason I'd like to use same fluid is I'm not sure if some of this milky discoloring is cross contamination either.
