Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Join Date
    May 2017
    Posts
    118
    Pictou County, NS, Canada
    Kioti DS4110
    Default Re: Advice for external power for fueling system
    I found a 250 gallon oil tank from a guy in town for free. Immaculate condition. Tonight I just picked up a rebuilt GPI pump (110vac and 30gpm) with a new hose and trigger nozzle. Now I just need to put it all together and get fuel delivered.
    I知 quite pleased with the setup. It should make for pretty comfortable refueling at -20.
  2. #12
    Super Member oosik's Avatar
    Join Date
    Aug 2012
    Posts
    5,398
    AMBER, WA
    Kubota M6040
    Sounds like the makings of a good setup. However - at those temps I think I'll remain inside and have a cup of hot cocoa. Believe me, retirement is a grand thing.
    Ride hard or sit your butt on the porch
    "isn't it weird that in AMERICA, our flag & our culture offend so many people - but our benefits do not"
  3. #13
    Super Member Wagtail's Avatar
    Join Date
    Jan 2013
    Posts
    6,026
    St Helens, Tasmania, Australia
    JD 4105 / JD D110
    Quote Originally Posted by Wagtail View Post
    I tried using my tractor's battery as power to the 12V fuel transfer pump (I've got a 50ltr tank, pump & nozzle set up on a wheeled pallet). It worked using alligator clips but really became a bit of a pain in the arse.
    I simply bought a small 12V marine type battery & mounted it on the fuel caddy. alligator clips onto the terminals when needed, off when not. Trickle charger every now and then when required.
    Now with picture "goodness":
    Attached Thumbnails Attached Thumbnails Advice for external power for fueling system-img_0218-jpg   Advice for external power for fueling system-img_0219-jpg   Advice for external power for fueling system-img_0220-jpg
  4. #14
    Gold Member
    Join Date
    Apr 2000
    Posts
    285
    Maryland
    Kubota L4060 Cab, ZD331, ZD326
    Quote Originally Posted by Chip Oidos View Post
    Hello
    I am a new tractor owner [if you look closely at my profile photo, there isn't any dirt on my tires] and I am trying to create a small refueling system for my JD 4052R. I am considering using a 55 gal drum with a 12V transfer pump (like a GPI 8GPM or 12 GPM pump). These pumps draw 11 amps and 18 amps respectively.
    I would like to run the pump off my tractors battery. The battery case is a bit difficulty to open and close so I would like to to somehow wire an exterior power plug to the battery or electrical system. The tractor comes with a power port but it is only rated to 10 amps.
    Does anyone have any suggestions for this type of set up? Are there better DC electrical connectors to consider than the "cigarette lighter" type?
    Is this a reasonable approach to refueling?
    Thanks
    If you are certain about using a 55g drum, then X2 on Anderson power connectors. I use them to power the fill-rite pump on my truck mounted diesel transfer tank.
    I also store gas in a 55g drum with a crank pump for my house backup generator, and it is a royal pain to fill with cans.
  5. #15
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,639
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Hello
    Thanks
    The difficulty opening up the hood to refuel made me look at just getting a small automotive battery and permanently attaching it to my Fillrite 15GPM pump. I hooked up a battery maintainer to it to keep it charged.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  6. #16
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    7,765
    Central Square, NY
    LS XR3037HC
    I use the Anderson plugs to power my fuel pump from the tractor. Works great.
  7. #17
    New Member Chip Oidos's Avatar
    Join Date
    Jan 2016
    Posts
    5
    Walla Walla, WA
    JD 4052R
    Thanks to everyone for the terrific advice and information.
  8. #18
    Elite Member
    Join Date
    Aug 2013
    Posts
    3,410
    Parker, CO
    Kubota L4060hstc, formerly L3200hst
    Quote Originally Posted by RjCorazza View Post
    "Anderson Plugs" is the designator for several higher amperage modular plugs. I use SB175s for jumper cables, winch power & other things. Power Poles is the designator for the ones that support up to 45 amps. They are designed slightly differently but use the same genderless design with the self wiping & cleaning contacts.
  9. #19
    Super Member
    Join Date
    Aug 2004
    Posts
    6,263
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Here is a neat transfer pump.
    Cheap (like under $15.00) and efficient with a plus that it self drains back to the drum so no smelly spills.
    Small Volume Oil Pump Water 12V 24V Diameter 38MM Wateoesel Aluminium Alloy Belt Filter Net Oil Suction-in Pumps from Home Improvement on Aliexpress.com | Alibaba Group
    I have one and was very impressed with performance. You have to supply the output tube and I found that radiator hose works best.
    Poly tubing simply gets too stiff with cold and as well I think fuel reacts to stiffen the poly.
    The flow rate is impressive so keep your hands on the power switch.
  10. #20
    Platinum Member DEWFPO's Avatar
    Join Date
    Jun 2007
    Posts
    885
    "High in the Rockies"
    2009 Bobcat Toolcat 5600 D
    I used a quick disconnect battery jumper kit similar to this one. Deka 2� Ft. Plug Connector Booster Cables by Deka at Mills Fleet Farm
    DEWFPO
    2009 Toolcat 5600 "D-Series", Hi-Flow, 29's, 72" SB-200, 84" Snowblade, 62" Lo-Pro Bucket, Titan HD 48" Pallet Forks
    SOLD - 2006 MF GC2300, 2350 FEL, 2315 MMM, 2360 SB, KingKutter CarryAll
Similar Threads
  1. Replies: 8
    Last Post: 10-27-2010, 03:00 AM
  2. Diesel fueling system for CUT owners
    By dfkrug in forum Build-It Yourself
    Last Post: 09-05-2009, 11:22 AM
  3. Dell external power supply source
    By Soundguy in forum Related Topics
    Last Post: 07-31-2006, 05:40 PM
  4. Banks Power System
    By jcmseven in forum Related Topics
    Last Post: 06-17-2006, 08:57 PM
  5. Sound System advice
    By OkeeDon in forum Related Topics
    Last Post: 04-15-2005, 10:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
