beltfed
Iseki 1610
I replaced the fuel filter and that was extremely dirty. I have about 20 hours on the tractor since I purchased it last fall. 900 hrs total.
No problem removing the filter and putting in the new one. I filled the bowl up with diesel fuel and tightened the top. Ran the tractor for 20 seconds and it died.
Opened up the first bleeder (closest to the fuel tank) and waited until just fuel came out. Tightened it up. Opened up the 2nd farther out from the fuel tank and waited till just fuel came out.. tightened it up.
3rd one.... I believe this is the correct one since fuel did run out. Opened up and after a bit tightened it.
It just won't start, I'm not sure if I flooded it... can you flood a diesel?
Here is a photo with each labeled 1 2 and 3.
