FILTER FOR DIESEL FUEL ?
   / FILTER FOR DIESEL FUEL ? #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
I need a filter to filter water and other debris for a 15 gallon Diesel storage tank.
What kind of in line filter do I need and where do I get it?
What fittings might I need to install it?
   / FILTER FOR DIESEL FUEL ? #2
I also have a 15 gallon fuel container, and black plastic jug for a chemical and I washed it out real good. The only problem I have is once I fill at station is getting it out of pick-up and then fuel in my Case, fuel filler is chest high? Last and first time I did transfer in 5 gallon container and fuel smells for a long time on shoes when I spilled alittle . There has to be an easier way and your filter idea, I like /forums/images/graemlins/smile.gif
Your fittings Will vary on size of pipe etc you use, I was thinking about putting a threaded fitting in the top with a suction tube to bottom of jug and add air to push diesel out with a flexible hose to Case 1845C
Jim /forums/images/graemlins/smile.gif
