HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Oil, Fuel & Lubricants
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 12-11-2006, 11:29 PM   #1 (permalink)
Default Poor Mans Fuel pump
I had bought a 55 gallon plastic drum of windshield washer to fill my rear tires and figured I would use the drum for fuel storage. I liked the fact that the side of the drum was graduated in 5 gallon increments and you can see the fuel level. I drilled a hole in each of the caps. The first cap I drilled the hole so that a 1/2 in cpvc would be a tight fit and inserted the dip tube. The second cap I threaded with a 1/2 male adaptor and glued on a gate valve and threaded on a quick coupling for the air hose. The filler hose is just a rubber garden hose with a male end and ball valve. To fill I put the hose in the fuel tank and open the ball valve, set my compressor output to about 10 pounds, crack open the gate valve to flow air. When I am down to my final gallon I close the gate valve stopping air flow. Fuel remains flowing from the drum still being pressurized so once the tractor tank nears full I slow flow with the ball valve and shut the valve when full. Then I open the gate valve relieving the drum pressure. I was amazed how fast the fuel flows and not a drop spilled.
jejeosborne is offline   Reply With Quote
Old 12-12-2006, 02:15 AM   #2 (permalink)
Default Re: Poor Mans Fuel pump
How do you fill the drum, with 5 gallons cans, or do you have diesel delivered?
__________________
2003 NH TC29D Hydro 4x4, 914A 60" Belly Mower, 7308 FEL, 5' King Kutter Rotory Cutter, 60" Midwest Box Blade, Woods 7500 Backhoe. www.4x4TractorWork.com
erosol is offline   Reply With Quote
Old 12-12-2006, 07:56 AM   #3 (permalink)
Elite Member
RalphVa's Avatar
Where did you buy the windshield washer fluid?
Actually, you could probably do this in a regular 55 gallon metal drum in its bung hole (e.g. air in/fuel out from separate holes in the bung).
However, I like the idea of being able to tell how much fuel you're putting in via the 5 gallon marks. I like to keep track of the gallons/hours and record them in a notebook when I finish each 5 gallon container. It's a pain to lift the 5 gallon containers up onto the hood each time though.
Ralph
__________________
The natural gardener
God's original intent
RalphVa is offline   Reply With Quote
Old 12-12-2006, 08:18 AM   #4 (permalink)
Super Star Member
Location: First organized permanent settlement in the northwest territory
Anyone else using free air over the pricey Elect. fuel pumps?
__________________
Tractors
2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500
60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
60'' MMM/Clamp on Forks/48'' MMM
South of Canton Ohio
L . B
LBrown59 is offline   Reply With Quote
Old 12-12-2006, 08:40 AM   #5 (permalink)
Super Star Member
Quote:
How do you fill the drum?
Do you have a filter on it?
Do you treat the fuel ?
Do you have a water separator filter on your compressor?
How do you drain off the water that accumulates in the bottom of the drum from condensation?
__________________
Tractors
L . B
Old 12-12-2006, 08:58 AM   #6 (permalink)
Nice setup, the see thru drum is a great feature. Compressed air can introduce some water into your fuel which can promote algae growth. If you don't have one you may want to install a oil/water separator on your compressor. You can pick one up at most supply places for around 10.00.
Coleman Powermate P024-0153SP Water & Oil Separator @ Air Compressors Direct.com - Your Online Air Compressor Superstore
Dave
dpdee13 is offline   Reply With Quote
Old 12-12-2006, 09:17 AM   #7 (permalink)
Super Star Member
Dave
I put one on my new Air Compressor when I got it last June.
__________________
Tractors
L . B
Old 12-12-2006, 02:31 PM   #8 (permalink)
Elite Member
schmism's Avatar
Send a message via AIM to schmism
ive hear the problem with a see through barrel like that (if its exposed to sunlight) it encourages the bacteria? that munch on the fuel and it grows that slime.... (although if you use the fuel in a timely mannor it should be THAT big of an issue)
(least i think i got that right... some one help me out hear)
__________________
Steve - TC33D 4x4 FEL, dual rear remotes with toys
schmism is offline   Reply With Quote
Old 12-12-2006, 07:52 PM   #9 (permalink)
Gold Member
I would be very careful pressureing a drum have seen them blow apart with not much pressure on them have seen a couple of guys hurt doing that trick the drum is not made to take pressure.
Dirthog is offline   Reply With Quote
Old 12-12-2006, 08:19 PM   #10 (permalink)
Elite Member
DieselPower's Avatar
Looks like a bomb waiting to go off to me to. At the least you should place a preasure release valve in it to prevent the drum from exploding and covering you and everything within 25 feet of you with fuel.
DieselPower is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.44328 seconds with 9 queries
