DTCOOPER
Okay guys,
I have always been a lucky one, never to worry about water in my fuel or some such horrors..
I had a 5 gallon can of diesel, that had sat outside for a week or so. During which time I think it rained. I thought, heck, that little bitty spout, surely not enough rain got into it to hurt anything.
Well, I should have known when I poured some into the garden sprayer and sprayed a bursh pile to burn it, and it was VERY SLOW TO LIGHT AND BURN.
Well, I poured the rest into the tractor (Case D33) since it was very low on fuel. I took off across the barn yard, to go push up some more brush with the FEL, and about 100 yards away, the tractor idled down very very low, spit a little white smoke, and had zero power, despite the throttle position.
It sat there idling about 500 rpm for 5-10 seconds, then died.
Any attempt to start it anymore, was met with it "trying" to start, and occasional puffs of white smoke. I tried for 15 seconds 2 or 3 times, and just stopepd and went inside for the night as it was already getting dark..
NOW that I have done this, what are my options? Is there a simple additive I can add to the mix? Do I need to drain the fuel tank, lines, etc, and start over with clean fuel? Is there a simple solution, or does any effective solution require much mechanic"ing" and down time ?
Help fellas !!
Daniel
Help fellas !!
Daniel
