SFish
The trick with the box blade without a hydraulic top link is to use the rippers to loosen the dirt over the whole area where you want to pick up dirt first. Then, with the rippers up find just the right amount of tilt that you pick up a big load, but it floats when the box is full so you can drag it to where you need fill and spread it. Run the tractor in the highest gear that it will pull.
On some box blades I have used there is a ripper position that just fits the fill and float tilt position so you don't have to rip it first. I learned all this from my Dad who was a schoolyard paving contractor in LA when I was a kid. He would use an 8N ford on weekends to finish up work left by the big machinery operators. You can move an enormous amound of dirt with a box blade.
steve
steve
