#1 (permalink) |
New Member
I'm new to three point hitches as you can tell. I've got 5 hours on my new Kubota BX24 and the instruction I received from the dealer was just OK. I've seen descriptions of drawbars and stablizers for the tree point hitch system but I don't know what they should be used for or if I even need them. I use a 42" woods rotary cutter, balast box and eventually a rear end snowblower (not sure ont he size yet....but will take some advice here too). Thanks.
__________________
bx24d |
#2 (permalink) |
Drawbars on the 3 point hitch, theres alot of opinions and here is mine. If you have a fixed draw bar on the tractor always use it, not the 3pt. If you use the 3pt draw bar there are some safety concerns. If you try and pull something it turns out to be more than your tractor can pull with a 3pt drawbar positioned above the rear axle you might flip over. If you have a trailer on a 3pt draw bar there is nothing keeping the bars from raising unexpectedly
there are several safety videos on this site that show some backflips and some threads that discuss chaining the drawbar to keep it down |
#3 (permalink) |
dghecas:
Firemanpat2910 is correct in his advise. If you need to pull something heavy and/or resistant towards movement always use the drawbar. I would suggest that you look at all your 3PH attachments as it relates to the drawbar. The drawbar can get in the way of PTO's, etc. I remove my drawbar when I am using attachments. Jay
__________________
NH TC29DA with 14LA and HD QA 60" bucket, weighted R-1's, FOPS, CCM M-160 (58") Tiller, Tebben MD 60" Rotary Cutter, Woods LR 108 (96") Landscape Rake, FEL cutting edge and tooth bar, Woods GB60 (60") Box Blade |
#4 (permalink) |
To answer the question on what a draw bar is used for...
The 3 point draw bar is the simple bar with holes that connect the lower lift arms. Most of the time you want to prevent it from spinning, so a stabilizer is needed. Now you can mount a ball hitch in one of the center holes of the draw bar and use it to move trailers around the yard. Once the bar is stable, it make hitching a breeze, just back up to the hitch and raise the 3pt, put in gear and go. That is all I use the drawbar for. When towing the sprayer or heavy trailers I always use the fixed drawbar connected under the tractor as Pat and Jay mentioned. There is no down force on your 3pt hitch, so if negative tonge weight is possible, never use 3pt. For towing stuck tractors or trucks, be sure to read that safety book and never connect a cable/chain to the top link, tractor tip-over everytime. |
#5 (permalink) |
dghecas You've just entered probably one of the most opinionated subjects on TBN, not referring to or disputing any of the above posters. I'll just try to answer your question and then give my opinion.
3pt hitch parts defined (sort of) You probably know what the lift arms are - heavy bars with ball socket attachments at each end for connecting to the tractor & implements. extend rearwards from the tractor. These are also attached to the 3pt lift mechanism by rigid or adjustable links. Drawbar- 2 definitions; the first is a rigid solid bar, straight or offset vertically, attached under the differential & thru a bracket under the pto also extending rearward from the tractor but not as far as the lift arms. Sometimes called a swinging drawbar. the second is a flat bar about 2 1/2 " x 1' thick x 26"+/- long with pin ends & several 7/8" holes that attaches between the lift arm ends. Stays - again multiple types Lateral stays attach to the pin ends of a drawbar at the lift arm and to pivot points under the rear axle just inboard of the brake backing plates. May be telescoping tube stock, rigid flat bars, turnbuckles, or chains in tension. All limit lateral movement of the implement but allow vertical movement. They form a triangle(s) with the rear axle housing & the drawbar pin ends. Vertical stays also attach to the drawbar pins but the top attaches to the toplink pin at the tractor and limit any verticle or horizontal motion as they form a rigid triangle. These appear to be uncommon & unknown to many TBN members but common on older tractors & older TBNers. Must leave the 3pt lift levers in the down position when using these stays. Drawbar locks prevent rotation of the second type of drawbar, by providing mechanical interference between the drawbar and the lift arms, when applying a load unequally to the top or bottom side ( like a hitch ball mounted on top of the drawbar). Some antirotation devices also connect a vertical member via toplink to provide a member parallel to the lift arms. I tried to find a picture of an assembly but couldn't. Hopefully the definitions will help if you search parts sources and view the parts. Now for my opinion. Common sense should prevail when hooking a tractor to any load but common sense comes from knowledge, lack of which can be fatal. The rigid "swinging" drawbar is highly recommended for pulling loads because of it's rigidity and placement below the axle. Pulling loads tend to pulll the front wheels downward and rear wheel slippage should occur before a wheelie does. This is not absolute because the distance from the axle back to the point of attachment is short and with sufficient traction a rearward overturn can occur. The higher the rear tractor wheels the more likely this situation. The other type of drawbar is often shunned because the 3pt lift mechanism has no downpressure. It will lift a lot but does not resist lifting loads. For example if you were pulling a single axle trailer that had negative tongue weight the 3pt would rise up and the load could push the tractor sideways. Also if a wheelie should occur the tongue hitting the ground would not stop the upward rotation of the front of the tractor. This is where the vertical stays come in to play as they resist the upward motion of the lift arms. This application is more subject to excessive tongue load wheelies than a swinging drawbar because of the distance to the rear axle pivot point. With each application any pull should be aligned below the tractor rear axle, NEVER above. On this site there are many drawbar adaptations that have potential negative safety flaws. IMO One of the most common is used to move gooseneck trailers, because in the travel position the ball coupling may be at or near the axle height. Take the time to gain an understanding of the forces in play & you'll stay safe, just understand that no method is absolutely safe. MikeD74T |
#6 (permalink) |
New Member
Thanks for a detailed and helpful description. I will search for some pictures to help. I'm most interested in towing a 6'x10' trailer around the property and occasionally a small lawn/garden trailer. Would the swinging drawbar or the straight drawbar be more appropriate on my subcompact tractor? I do understand that I would need to remove it to use the three point hitch with other implements.
__________________
bx24d |
#7 (permalink) | |
Elite Member
Quote:
I do suggest you use a spring or bungee to keep the lower links from flopping around too much. There may even be loops welded to the lower links for this. And, watch your speed going down hill if you have a load on that trailer. tractor brakes aren't so good. Also, there's no reason to remove the tractor draw bar when using the 3PH. If you extend the draw bar, you may have to reposition it, that's all
__________________
Roy Jackson JD 790 w/ FEL The 790, a tractor with a vertical exhaust and a hard gear shift lever...symbolic of the MANLY man |
#8 (permalink) |
dghecas Since you have a 3pt drawbar capacity of 670 lbs at 24" behind the axle you can use either provided you maintain adequate tongue weight. If there's any possibility of negative tongue weight (ie loading/unloading something heavy at the rear of the trailer) use the swinging drawbar. MikeD74T
#9 (permalink) |
Super Member
I made a slightly different three point drawbar for my little B7100. Picture attached.
__________________
Egon 50 years behind the times Livin in a Worn out skin bag filled with rattlin bones |
#10 (permalink) | |
Quote:
Dougster |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
