EastTnFarmboy
- Joined
- Sep 3, 2007
- Messages
- 177
- Location
- East TN
- Tractor
- Kubota L5240 ROPs FEL, JD LX277, Ferris 3100Z
I took delivery of a new Kubota GL5240 HST this afternoon. After finish mowing for a couple of hours, I unhooked the RFM and went down to a pile of logs to test out the Grapple I had purchased with the tractor. It was almost dark, so I wasn't doing any heavy work whatsoever. I was basically trying to get a feel for the way the FEL joystick and 3rd Function worked. The loader didn't seem to be lifting very well, and then all of the sudden I heard a hissing noise. I looked down to my right and fluid was spewing out of what I presume is the 3rd Function Valve. It is mounted under the right side of the floorpan and has a box covering it with a sticker that says "No Step". I was only a couple hundred feet from where I park the tractor so I just stepped on it and parked it before I shut it down. Of course, I left a well defined trail of fluid across the field.
After parking it and letting it set for a few minutes while trying to figure out where it was coming from, I started it again for just a few seconds. It was just gushing fluid out of the aforementioned "valve".
What would cause this on a brand new tractor? The best I can tell, it is coming out of the top of this thing. I have attached pictures to illustrate (after removing the "no step" box that covered this. I cannot find any hoses leaking. If you look you can see where it is leaking where the top part joins the base. I can't imagine that I did anything to make this happen, but who knows.
Any thoughts? Thanks!
