Ballast BALLAST BOX
   / BALLAST BOX #11
flINTLOCK said:
Since I don't weld, I'll probably have to rely on storebought, unfortunately.
Ya don't hfta weld.
if you can mix 'crete and have a few hand tools.. you can make as big as ya want.
here's one that cost me uh.. maybee 15$.
The tub was a cattle feed tub... leftover... there is an old drawbar bolted under it, and then some metal flats sticking out the top that are drilled to take the toplink pin.
Pretty much all i paid for was the concrete.. and some long carriage bolts to bolt the drawbar to the bucket and leave some thread stuck up in the crete for it to grab on to.
Soundguy
   / BALLAST BOX #12
Looks like a good weight bucket. Pretty in-expensive also (compared to steel).
   / BALLAST BOX #13
Yup, that's what I did too.
Bought a cheap rubber trash can from Menards.
Bought a cat 1 drawbar
Bought two pieces of flat stock steel
drilled a hole throught the sides of the trash can just big enough to slide the bar through. Slide bar in.
Mixed up enough concrete to fill it. Bend the flat stock end to a 45* so it won't slide out if loosened. Put the metal bars in the concrete before it dried.
Drilled a hole through the top of the metal to slide a hitch pin in to hold top link.
I probably have about 500+/- lbs and it works pretty good. Total cost was probably ~$50
   / BALLAST BOX #14
Yep.. Mine was cheap too. I had carriage bols up in the bucket with the threaded studs sticking a couple inches down to bolt the drawbar to. If I want to ditcht he thing, I just run 2 nuts off and get my drawbar back.
Ditto on bending the metal for the toplink connection.. I bent mine l shaped at the bottom.
I like that design.. cheap.. but works.. if it breaks or gets beat up.. no big deal.. has a flat top to pile a chain or strap on. Only thing I would do different if I build another is to put a sleave tube in it that would accept a trailer toungue.. etc..
Soundguy
   / BALLAST BOX
Trying to figure how much cured concrete weighs compared to dry sacrete in bags. Probably 10-20% heavier, ya think??
   / BALLAST BOX #16
I bolted some expanded steel to the top of my BB and strap 6 buckets filled with concrete to it for weight. gives me close to 1000 pounds of ballast - and I still have the BB to flatten out whatever i just moved if I want to.
no welding involved, just a couple pieces of scrap angle and some bolts to tie the mesh to the top of the BB.
   / BALLAST BOX
I guess my question was if I buy 10 50# bags of sacrete, will I end up with 500# of cured concrete??
   / BALLAST BOX #18
I believe concrete average is 150lb per cu. ft.
So if a 60# bag = 1/2 cu. ft. cured it should weigh roughly 75lb.
   / BALLAST BOX #19
If you start with an 80# bag of material, and only add water to it, the resulting mix weight can't be more than the combined weight of the mix plus the water. Since an 80# bag of quikrete calls for adding 6-9 pts. of water, that would be an additional 6+-9+ pounds, bringing the total to 86-89 pounds of wet mix. Now the tricky part... you would think that the water would evaporate and the cured concrete would weigh less than the wet mix... the way I understand it, however, is that during the hydration (curing) process, the concrete actually retains (and may increase) the amount of moisture in the hardened concrete. If that is the case, the original 80# bag of mix would result in 86-89+ pounds of cured concrete. For ballpark purposes, it seems that if you just add 10% to the original weight of the bag mix, it should get you in the range for the cured weight.
As a sanity check, this would mean an 80# bag would result in 88# of concrete... since an 80# bag produces .6 cu ft., this would mean a cubic foot would equal 147#, which is right on target for the average weight of conrete.
   / BALLAST BOX
Nice description. Just what I needed to know. Thanks much.
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
MULTIQUIP WHISPERWATT MQ POWER 25 GENERATOR (A52706)
MULTIQUIP...
2023 Club Car Carryall 700 Utility Cart (A55851)
2023 Club Car...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
2003 Big Tex 10PI...
