Snow Equipment Owning/Operating Landscape rake and snow
   / Landscape rake and snow #1
Solo
Fairmont,WV
New Holland Boomer2030
I asked the question last winter, Would plowing snow with a landscape rake be effective? . I got answers from no it won't work to a few positive answers of yes it will. Today I got to try it. It worked very well. All I really wanted to do was bring the gravel to the surface to provide traction. I don't think this method would do very well in deep snow. I have about 5" of snow on my driveway. By bringing the gravel to the top, what little sun we have had today, has been warming the gravel and melting the snow. I guess if the snow were really deep you could plow it off with a blade and then use the rake to finish. The other advantage with the rake is I am actually grooming the driveway at the same time. Saves me an extra trip when the snow does melt.
Solo
   / Landscape rake and snow #2
Solo, I think the landscape rake is the most over looked implement there is when it comes to snow removal on stone roads or driveways. If we have deep snow I high blade it off first with my front blade and then follow up with the landscape rake. It works great and as you said, pops the stone to the surface for better vehicle traction, plus it aids in faster melting. You can also use the rake on icy roads or driveways to get some stone popped on top of the ice for traction. If you angle the rake sharply it will also tear up thin ice that has formed on the road. I've been using a landscape rake and blade combination for about 13 years now and wouldn't use anything else.
Sincerely, Dirt
Note: I had attached a blue tarp on the rake to prevent stone from bouncing off the rear of the tractor or breaking the rear window. I have since improved this by using a piece of indoor-outdoor carpet.
Dirt
It works better than I had expected. Now I know what my first choice for snow is.
Solo
   / Landscape rake and snow #4
While I don't use my rake in the winter The carpet is a great idea. I'm going to do that to mine this winter. Grooming my trails is like target practice with me and the 1910 being the target.
   / Landscape rake and snow #5
Solo, I'm glad you learned that a landscape rake can be a valuable implement for snow removal.
ccsial, I'll post a couple of pics of the rake with how I put the carpet on. Maybe you can even think of ways to improve what I came up with. The main reason I installed it was because of the glass on my cab. The second reason was the rear of my old JD 870 had a million stone chips on it.
Sincerely, Dirt
   / Landscape rake and snow #6
Sincerely, Dirt
Thanks Dirt, I'll look forward to that.
Al
   / Landscape rake and snow #7
ccsial, here are the pics of my landscape rake that I added the indoor-outdoor carpet to deflect any stone away from the rear and glass on my tractor. If you have any questions feel free to ask.
I started by doubling the carpet for added strength. Then I punched holes so I could install grommets in the holes to prevent the holes from tearing out once the bolts were installed. I put the folded edge of the carpet towards the ground. Once the grommets were installed I marked and drilled the rake frame so that I could bolt through the gromlets and rake frame. I kept the carpet about 1-1/2 inches off the ground when the rake is fully lowered,so it wouldn't wear from coming in contact with the ground.
The below pic shows the carpet mounted on the landscape rake.
The below pic is of the landscape rake from the rear.
The below pic is a close up showing the bolts thru the grommets.
   / Landscape rake and snow #8
Before I got a front plow, I used my landsape rake at the rear to plow my driveways. I bolted a 2x6 to the tines so it worked as a rear blade. I let the teeth show an inch or so to scrape thru the gravel.
   / Landscape rake and snow #9
Thanks Dirt,
That looks good. I have the same rake you do except I painted mine Ford Blue. I also added gauge wheels and a tow bar for my water trailer. I'm going to do the same thing pretty soon. I have been thinking I needed to do something but have not really thought much about it. This looks like a real good solution.
Al
   / Landscape rake and snow #10
ccsial, geez now I wish my rake was all painted up and clean.lol. Not my color but,nice looking set up. You will find that the carpet works really well to keep any stone from bouncing of the rear of the tractor or even you. I had been hit a time or two on my old open station JD870. I also was amazed at the amount of little stone chips on the back of the 870.
Sincerely, Dirt
Poulen Pro 6000 Watt Power Generator (A50860)
Poulen Pro 6000...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
KUBOTA 1140CRX RTV (A51406)
KUBOTA 1140CRX RTV...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
