Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,765
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: 3 Pt. question?
    Draft control just causes the 3pt arms to lift (not lower) to bring the ground-engaging attachment up enough to relieve the load. When the load is releived, the arms go back toward their previous position. The draft control often is a spring-loaded assembly that the top arm is attached to, which is internally connected to the 3pt lift control. Well, at least its clear in my mind.
  2. #12
    Join Date
    Apr 2000
    Posts
    349
    Peculiar, MO
    B2400 Kubota
    3point equipment are designed to engage the ground on their own force. If you think you need downward force, you need a different type of equipment, such as a plow or chesiel instead of a tiller. Think of the damage that can result from forcing equiopment into the ground trying to do a task it was not designed for. Yes there was times when I wish I had a down force, but thank God I didn't for i probaly would have done real damage. Again there the right tool for the right job. Just think more tools. I asked my brothers who farm with the big equipment about downward force 3pt and their comment was the ones who have added the downward force, tend to be repairing the equipment more then using it.
    Dan L
  3. #13
    Veteran Member hayden's Avatar
    Join Date
    Sep 2000
    Posts
    1,769
    MA/VT
    Kubota L5740 cab + FEL, Kubota KX121 excavtor
    OK, thanks for the clarification. I though it set a fixed depth, and woud push up/down to achieve that depth. Shows what I know.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
