The weather has everything on "hold" right now, so I thought I'd take this time and ask for your input. I have purchased 24 acres and plan on building a home within the next year. A wheat crop was harvested off of the land last year and since then, I've just taken a 6' bush hog behind my JD 3320 and mowed down the stubble and weeds for a cleaner look. My plan is to plant a mixed blend prairie grass but want to make the surface as SMOOTH as possible. My original thought was to buy a 6.5' disc harrow that I would use to work the land after burning it off this spring. My thought behind the burning would be to make disking easier because I wouldn't be working with as many weeds, etc. After disking, my thought was to run a drag harrow over it to smooth it out and then have my friend use his drill to plant the seed. I'm looking for suggestions on the most efficient way to do this with the tractor I have. I can borrow a field cultivator instead of buying a disc, that would save me $750, but is it going to give me the finished product that I want? Also, if you have suggestions on time of year to plant along with pre-planting spraying to kill the old and fertilyzing in prep for the new. I know I've asked a lot, but appreciate your input.
