Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Elite Member
    Join Date
    Apr 2000
    Posts
    3,808
    Craftsbury Common, Vermont
    Deere 4044R cab, Kubota KX-121-3S
    Default Re: How to tell if wheels are loaded
    So the idea is that by blocking ADH the ethylene glycol passes before the nephrons can touch the stuff..? Now that's practical advice! Does it work on dogs? I dread my dogs finding an antifreeze leak among the tourists parked below.
    Pete
  2. #12
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,289
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Nah..... just salty water.... like swimming in the ocean...
    I think it was the concentration that got me!!! Yecchhh!
    Glad I checked it though..one rear tire is loaded, the other not. I've called the dealer I bought the machine from...they'll take care of it, but I got to get the wheel to them...
    However, they use windshield washer fluid, not CaCl.
    So, reckon I'll do one of three things:
    1) Pull both wheels off...down to the dealer..get 'em filled.
    2) Call a company to come fill them (not too many in York County, PA...surprisingly!!)
    3) Fill them with windshield washer fluid/water myself.
    I'd like to do (3). Since a few of y'all have done this..Bird!! Ya listening???), is it a job that can be reasonably well done by one guy (maybe assistance from wifey)?
  3. #13
    Join Date
    Mar 2002
    Posts
    80
    SE Wisconsin
    Kubota BX2200
    Pete,
    I'm guessing that it will work with dogs as well, but you ought to check with a vet concerning this. Part of the issue is that by the time you notice antifreeze poisoning in a dog, it's because they're dead (or close to it). It's the old "ounce of prevention being worth a pound of cure".
    Desperate alcoholics would drink antifreeze, and then go into the ER and let them know what they did. The cure is an IV gin-'n'-tonic... [img]/w3tcompact/icons/smile.gif[/img]
  4. #14
    Member
    Join Date
    Mar 2002
    Posts
    29
    Magnatrac 6000, Ariens GT17
    Give them a breathalyzer test. [img]/w3tcompact/icons/wink.gif[/img]
  5. #15
    Member
    Join Date
    Mar 2002
    Posts
    29
    Totally off the subject, but on the subect of swollowing funny things. I was having a fitful dream 'bout an hour ago at the end of which I was eating glass, I woke up with a lump going down my throat. It wasn't painful so I guess I'll just wait it out. So that's why I'm on tonight. If I stop writing posts, you can guess why....[img]/w3tcompact/icons/smile.gif[/img]
  6. #16
    Super Member
    Join Date
    Apr 2000
    Posts
    5,673
    Cedartown, Ga and N. Ga mountains
    1998 Kubota B21, 2005 Kubota L39
    Roy,
    If you take a look in the "Customiztion" forum there is a current tread named “Riggin’ for steep slopes”. A number of ideas for filling tires are discussed as well as a description of how I did mine at home.
    MarKV
  7. #17
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,565
    Texas
    Roy, there's been a lot of discussion about the little air/water adapter valve you can buy for less than $10 to hook a water hose to your valve stem, to just use a garden hose to put water in. I put two gallons of antifreeze in each of my rear tires with the gadget shown in the picture, then put the water in, but I was using home made tools for both. For windshield washer fluid, I think I'd probably buy the air/water adapter and use it with one of those little drill powered pumps. And yes, I think it's an easy enough one person job, but of course, I've worked on tires off and on all my life.[img]/w3tcompact/icons/wink.gif[/img]
    Attached Images Attached Images
  8. #18
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,725
    Nova Scotia, Canada
    Bird:
    I seem to recall seeing a tractor rim that had a threaded weldelet collar welded on to the rim and then the rim was drilled out. A valve with bull plug was then threaded in and this was used to fill the tire with liquid. If memory serves correctly it was a 1/2 in. valve. Have you ever seen this done? It was probably on a larger tractor.
    Egon
  9. #19
    Join Date
    Mar 2000
    Posts
    40,565
    Texas
    Egon, I don't recall seeing anything quite like that; don't know whether I've just never seen it, or whether I've forgotten it.[img]/w3tcompact/icons/wink.gif[/img]
  10. #20
    Join Date
    Nov 2001
    Posts
    22,289
    Bethel, Vermont
    Thanks to both Bird and Mark!!
    I've copied the instructions from this thread and the one Mark mentioned.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
