Page 103 of 798 FirstFirst ... 35393100101102103104105106113153203603 ... LastLast
Results 1,021 to 1,030 of 7975
  1. #1021
    Join Date
    Sep 2008
    Posts
    112
    Mid-Michigan
    LX-176 (not really a tractor)
    Default
    New B2320, just hitting 10 hours. Past two days ~ 5 hours filling 4-yard dumpster-needed 10-yard-with various debris then pushing logs on back lot to clear area to dump countless loads of rotten wood + creating 3 new parking spots for tractor etc. I found 20" rotten fire logs I'd stacked 16 years ago + old rotten dock sections with nails, all under years of leaves. Why oh why did I save this stuff?
    Tractor is a marvel but with plain old FEL I did a ton of 'hand loading' logs into bucket & my lower back knows it. This little machine can push stuff though; love it.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-image-2208562010-png   TODAYS SEAT TIME-image-554300712-png
  2. #1022
    Platinum Member soulasphil's Avatar
    Join Date
    Nov 2008
    Posts
    504
    France
    JD 3520 powerreverser
    Default Re: TODAYS SEAT TIME
    Did some mowing today. Reached the north side of the property, which brings the present pass to an end. Will be able to put the deck away at least for a week.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-dscf1589-r-olution-de-l   TODAYS SEAT TIME-dscf1585-r-olution-de-l   TODAYS SEAT TIME-dscf1586-r-olution-de-l   TODAYS SEAT TIME-dscf1587-r-olution-de-l   TODAYS SEAT TIME-dscf1588-r-olution-de-l
    TODAYS SEAT TIME-dscf1590-r-olution-de-l
    3520 PR
  3. #1023
    Elite Member Mousefield's Avatar
    Join Date
    Aug 2008
    Posts
    2,620
    Qualicum Beach on Vancouver Island, BC. Canada
    Sold 2008 CK35 HST
    Finally got some of the other projects done so that I could get to using my auger to drill some nice fence post holes. Got started today and hope to have all the holes done by tomorrow.
    As a bonus it was sunny all day.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-augerwaterbug-007-jpg   TODAYS SEAT TIME-augerwaterbug-009-jpg
  4. #1024
    Join Date
    Jun 2010
    Posts
    701
    north Mississippi
    NH 3040
    bush hogged all the roads and food plots on a 500 acre lease. I was opening one on the gates with the slide pole in the middle(that allows owner and leaser to have access) when about 100 red wasp lit into me. I will be sore for a while. Plus I had to run back up to the gate to get my tractor.
    NH 3040 fel 6' cutter
    JD 737 zero turn
    polaris ranger xp
    99 honda 300
    Trek Emonda SL8.
  5. #1025
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,668
    central Wisconsin
    Kubota B7800, B26 TLB
    Finished up a driveway job today. 4 18 yd. truckloads of sizzler stone. Nice stuff, better than limestone in my opinion. Had a lot of prep to do before hand. A garage was built in a "hole" and the apron had a pond by it after every rain. To complicate matters there were numerous buried electrical cables in the area that needed to be excavated. After consulting with the land owner we decided to lower the area by the apron and create a swail for drainage in the opposite direction. Material removed was relocated to some areas that were low and saved an extra truckload of sizzler. Many rocks were encountered but this one was memorable. Only a bit was showing when I started but this is what came out after 10-15 minutes of effort!
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-mvc-257f-jpg
    Working to increase the scope of the small tractor experience, one quick attach at a time.
  6. #1026
    Member Archer EV's Avatar
    Join Date
    Jul 2011
    Posts
    49
    S. Illinois
    Long 2360
    My seat time started by removing the seat...to get at the 3pt hydraulics. My Long 2360 developed a pretty bad leak a couple of weekends back. It was running out from the hyd. valve cover plate and all down the trans-axle. After I removed the plate, I found the source of the problem was a 4 inch diameter O-ring. and of course the gasket broke in the process of removing the plate. I made a run to town and found some gasket material and a replacement O-ring. I cut out a new gasket with an Exacto knife, installed it and the O-ring and voila', no more leak!
    After the repair, I bush hogged an acre as a "field test" and bush hogged a couple of trails in the woods. I was getting low on fuel so I knocked off. Tomorrow I will get some diesel and finish that back field for sure...unless it rains.
  7. #1027
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    First time with my old beater Iseki rotovater on the new LS today. 3PH was a little different and the PTO shaft had to be shortened to get it to fit. It was way short already. Took off one more inch and it fit. Ran it for about an hour before the PTO shaft gave up the ghost. The female tube blew out, apparently not handling having only about three inches of overlap. Hopefully I will get a scrap of that funny shaped tube from a cut off scrap at the dealer if they have one. It only has to be about 7 inches long. I will reinforce several inches of the working end by wrapping it tightly in thick high tensile steel wire, clamping that in place, and brazing it solid. That should make it strong enough to be that short.
    Now it's getting close to 90 degrees out there for the first time this year. I'm going to stay indoors until it cools back down. I know, I know, I'm crybabying. Not used to it.
    The Corporate Empire is NOT a Constitutional Republic...
    ...but it plays one on TV.
  8. #1028
    Join Date
    Aug 2010
    Posts
    157
    Norman, OK
    Mahindra 3316HST
    Pulled a(nother) car out of the ditch. The driver offered to pay, but I declined.
    Karma treated me right, though--the plumber only charged me $60 for the Sunday callout instead of $145 (turns out my septic tank is full), and the tire shop made such a mess of things that the comps brought my $700 bill down to just under $400.
  9. #1029
    Silver Member D33r3 6r33N's Avatar
    Join Date
    Jan 2010
    Posts
    198
    Logan County, OH
    John Deere 2305, Scag 19hp 48" Tiger Cub
    Default
    Finally got the tree cleaned up that some high winds snapped off. I cut it up yesterday and cleaned up the mess today. Pretty cool how even clamp on pallet forks will just scoop up that brush so you can carry it away.
    Here is pics of the tree, the wind blew it about hundred feet before it smacked into the telephone pole.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-forumrunner_20110821_232503-png   TODAYS SEAT TIME-forumrunner_20110821_232551-png
    John Deere 2305
    ----200cx FEL, 50" LandPride RTR tiller, 5' RB, 4' Howse BB
    5'x10' Dump Trailer, 6'x16' open deck trailer, 5'x10' mower trailer
    I post via the Tractorbynet.com app
  10. #1030
    Join Date
    Aug 2008
    Posts
    2,620
    Sold 2008 CK35 HST
    Had some rain overnight and this morning so it's a good time to grade the road. The damp gravel spread very nicely over the road. It wasn't in bad shape but nice and smooth now.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
