Page 136 of 837 FirstFirst ... 3686126133134135136137138139146186236636 ... LastLast
Results 1,351 to 1,360 of 8366
  1. #1351
    Super Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar (For Sale), CS261, & FS190 + Echo CS400 & rusty old Ranger snowplow truck
    Default Re: TODAYS SEAT TIME
    Yesterday I managed to get about an hour of seat time (finally!).
    The bucket was on so I used it to dig into a pile of slash and dirt.
    I am still learning how to use the bucket, plus having a jumble of 4' to 7' small log chunks jumbled in amongst the dirt was just not very effective.
    I also tried to see if backdragging the mulched debris with the bucket & tooth bar was more or less effective than the grapple. I did manange to clear some tractor trails, but the grapple is simply more effective.
    So I changed it out. I discovered the hyd QD's are SO MUCH EASIER 2 handed
    So I learned a couple things, and made a little progress clearing the pasture space.
    It was good enough.
    Be well,
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, Titan 48" Pallet Forks, & more to come. & 2003 JD LX266 42" deck mower.
    Managing 51 Acres of Virginia hills with ponds & streams, Freshly replanted Loblolly!, riding trails, empty pasture, long gravel drive, garden, & yard.
  2. #1352
    Silver Member lstinthot's Avatar
    Join Date
    Sep 2011
    Posts
    165
    Spotsylvania, VA
    CT230
    Quote Originally Posted by k0ua View Post
    His error was ignoring the 2 inch tree in the way and attacking the 10 inch tree. Pushing over tree's with a tractor is doable. You just have to be very very careful. There are several dangers, Never push over dead trees, they always break off up higher and fall on your hood or your head. Never ram a tree, apply power slowly. Dont overdo it, by trying to push over too large a tree, and breaking or bending something. Push trees a couple of days after a rain, preferbly, so the upper soil is firm, but the roots are still in looser wetter soil. Look first for widomakers or dead branches liable to break off and fall on your head. But if you dont feel comfortable doing it don't do it. Now again his error was not removing the 2 inch tree and keeping his work area clean before he attacked the larger tree. Always clean your work area, as you clear land, never leave anything that your tractor has to work over, be that small trees, large rocks or holes. Clean and repair, then move forward for the next victim.
    One advantage to pushing over trees is there is no stump left to deal with.
    James K0UA
    Thought this was going to be a quick push since it was already a leaner and ground was soft, ended up cutting smaller tree with chainsaw to get it out after the fact. You always have time to do it right the first time.
    I could have used the chainsaw, just don't like it when they are already leaning. I guess this one was not ready to give up yet. Will take chain saw to it, then use backhoe on stump.
    Widow makers are throughout my woods, I learned that lesson a few years ago. You don't know what you don't know when you start playing with heavy equipment in the woods. Was pushing a dead tree with a JD450 (track loader), had the bucket up high just pushing, then started to rock a little. It started raining limbs, 3 and 4 inch limbs 3 and 4 feet long. Fortunately I had a heavy duty canopy on that tractor. One of the branches came down like an arrow right into the radiator cover. Many others fell on the canopy. That is when I realized I was lucky to have the tractor I had and not an open type.
  3. #1353
    Silver Member Window Geek's Avatar
    Join Date
    Apr 2008
    Posts
    217
    Central Mass.
    2006 Kubota 7610 HST 4WD
    Default
    There was a"little" trees and limbs to clean up after the early snow storm. The brush forks did great. Gotta wait till January for the burn permit. Should be even more fun then!
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-image-2178981268-jpg
    [#] Window Geek
    When my wife said, "You've waited long enough for a tractor. Go get one.", I knew exactly what to say:
    "YES DEAR."
    Kubota B7610 HST 4WD
    LA352 FEL, B2765A front blade, 3 pt carryall, bucket forks, spreader, lifting boom, 2" receiver, TSC PHD, KK II 4' rototiller, Salsco chipper, towable splitter, homemade 3 pt pallet forks, 7' back blade, 6' yard rake w/ homemade gauge wheels, HF Quick Hitch
  4. #1354
    Join Date
    May 2011
    Posts
    826
    Trent Hills, ON
    Kioti DK40SE HST
    I moved a couple yards of dirt and gravel to make a level pad for my tractor shelter. I had no trouble digging into the turf but big clods of grass are annoying to work with and take alot of driving on to get packed in.
    2011 DK40SE HST
  5. #1355
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Quote Originally Posted by Window Geek View Post
    Window Geek,
    Please tell us about the rack I see attached to yout ROPS.THAT looks very interesting!
    Thanks in advance,'
    David
  6. #1356
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    Quote Originally Posted by MossflowerWoods View Post
    Window Geek,
    Thanks in advance,'
    David
    Indeed, looks like a good place to haul a chainsaw.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  7. #1357
    Member pmetal's Avatar
    Join Date
    Sep 2011
    Posts
    32
    Stafford, VA
    Bobcat CT235
    Attacked my brush pile this weekend. (I'm sore in places I didn't know existed! )
    Rented a 6" chipper, and man, was that thing awesome!
    Unfortunately, I didn't take a "before" pic, but in the first picture I marked how high the pile was. I'd say about 15 feet tall, probably 10 feet deep.
    Used the tractor to pull the brush and trees out to be chopped and sawed up. NEVER could have done all this work without the tractor.
    The outcome...
    Will probably use the chippings on some of the trails behind the house.
    Ended up with small wood pile. I was gonna use it as bonfire material, but I found out one of the new neighbors has a wood-burning stove, so I invited him to come take whatever he wants. I'll use the left-overs for the bonfires.
    Still have some clean-up to do, but we put a HUGE dent in it.
    Loving the Bobcat, that's for sure! I'm up to 16 hours on it, with many more to come (hopefully).
  8. #1358
    New Member hotdogL553's Avatar
    Join Date
    Jun 2011
    Posts
    3
    New Holland L553
    Another problem to look for when pushing over trees, is the root ball.
    Depending on the tree, the root ball can get lodged under things like
    FEL, axles, engines and the like. When the tree falls over if the root ball
    is big enough, it really gets your attention when the front of the tractor
    raises up. It can turn you over. Be careful all.
    Thanks, Hotdog
    Semper, Fi
  9. #1359
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Quote Originally Posted by pmetal View Post
    If I might ask, how much was the rental on the chipper for the weekend?
    Did it have an hour meter? How long did it take to chip that much?
    Thanks in advance!
    David
  10. #1360
    Join Date
    Sep 2011
    Posts
    32
    Stafford, VA
    Bobcat CT235
    Thanks in advance!
    David
    It was $250 for the weekend. I picked it up Friday afternoon and had it back to them this morning by 8:00 a.m.
    There was a meter on it. I glanced at my receipt this morning and I want to say I had ran it for about two hours. Not even long enough to empty the gas tank. I will double check that tonight when I get home.
    Some of that time it was idling while we pulled more debris from the pile. Hook up the chains, pull three or four trees out, cut the limbs, pile 'em up, etc... If I had everything ready to be chipped, it would have gone a lot quicker.
    I was probably out there for about 8 hours on Saturday, had two friends come by for about 6 hours to help (and what a help it was!!!), and 3 or so by myself on Sunday.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
