Page 178 of 823 FirstFirst ... 78128168175176177178179180181188228278678 ... LastLast
Results 1,771 to 1,780 of 8224
  1. #1771
    New Member
    Join Date
    Sep 2011
    Posts
    16
    MF 250, MF35, Ford 8n, JD 45 Combine
    Default
    I got about 3 hours of seat time last weekend on my MF250. Went over to the co-op and got my bulk fertilizer and their buggy. Put down about 100 lbs an acre of granulated urea (46-0-0) on the winter wheat. Rain was forecast the next day so it was perfect timing.
    With a new baby here, I got a little behind picking up the spreader, so I wound up figuring out how to spread fertilizer in the dark too.
  2. #1772
    New Member
    Join Date
    Sep 2011
    Posts
    16
    Default
    With a new baby here, I got a little behind picking up the spreader, so I wound up figuring out how to spread fertilizer in the dark too. That's par for the course around here (we call it Moonlight Farm for a reason) as I did almost all the prep last fall and the planting in the dark as well.
    Hope everyone is enjoying spring!
    TODAYS SEAT TIME-forumrunner_20120317_124805-png
    TODAYS SEAT TIME-forumrunner_20120317_124825-png
    TODAYS SEAT TIME-forumrunner_20120317_124849-png
    TODAYS SEAT TIME-forumrunner_20120317_124916-png
  3. #1773
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,599
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    Default Re: TODAYS SEAT TIME
    I cleaned up the edges of my road today. The snow is almost gone. The frost is coming out of the ground. Everything is pretty soft right now. It is a good time to go down the road edges with the rear blade to clean out leaves and fix any snow plow damage that might keep the water from running off the edge. I put the blade in the offset position so I don't have to drive on the soft edge. With the blade angled to pull material in, and a little tilt to keep the edge low, I run it reversed. This seems to work good for me. In a couple or three weeks it will be dry enough to grade.
    50* F today. What a spring !!
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-offsetblade1-jpg   TODAYS SEAT TIME-offsetblade2-jpg
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  4. #1774
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Default
    I put my new T4 48" rototiller on my kubota B2620 today. Tiller under some leaves and expanded the garden size for this year. It's been unseasonably warm here in mid-Michigan (80 today) but still too early to plant of course.
  5. #1775
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,491
    Somewhere north of Roseau, MN
    Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
    Unhooked the snow blower, thus guaranteeing at least one more squall , took the winter cab off the tractor and started pulling trees out from behind the old chicken coop, hoping to make space for a new chicken yard. As it happens, the ground is still frozen, so the bigger trees will have to wait for a while, as they're not budging yet. Finished off the weekend by hauling more brush to the pile.
    Joe
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-0316121144-jpg   TODAYS SEAT TIME-0316121521-jpg   TODAYS SEAT TIME-0316121522-jpg   TODAYS SEAT TIME-0316121650-jpg
    Joe
    Fordson Major Diesel: Case 3-bottom Trip Plow, Case 12' Trip Field Cultivator, Kewanee 130 Disc, John Deere 1209 Mower Conditioner, John Deere 594LW Side Delivery Rake, New Holland Hayliner 273 Baler, 18' Spike-Tooth Harrow
    Ford 1510: Du-Al 105 Loader, "The Thumb" Grapple, Bush Hog RBC60 Rear Blade, Woods HC54 Rotary Cutter, Tarter 5' Heavy-Duty Hinge Back Box Blade, Buhler Farm King Y600 Snowblower
  6. #1776
    Veteran Member JohnDeere4300's Avatar
    Join Date
    Feb 2005
    Posts
    1,565
    John Deere 4300
    I got 4.3 hours of seat-time yesterday digging a big hole for a guy down the road that's building a storm shelter!... That's also hauling all the dirt away in the 4.3 hours!
    The hole is 8'X8' and 7' deep!... The dirt is all clay, and I hit water about 3' down and the hole started filling up with water, So we had to set a pump!
    I'll have to go back down to do some cleanup on Monday and I'll take a few pictures!
    Bill
    John 3:16
    01 JohnDeere4300 "Sync-Reverser", Vertical Exhaust, 2 JD Lawn Tractors, JD Walk Behind.
    430-FEL/ 47-Backhoe/ 5' Bush-Hog/ Single Bottom Plow/ 6' Disc/ Aerator Spreader/ HF Quick-Hitch!
    (Homemade Stuff) BH Thumb/ Log-Hitch/ 10' Boom-Pole/ 42'' Pallet Forks ''FEL Quick Attach & 3PH Quick-Hitch-Attach''/ Ballast Box 1381 lbs./ Aluminum Canopy/ Brush-Guard Mod/ 5x10 Firewood Trailer/ Lawn Striper.
  7. #1777
    Join Date
    Nov 2010
    Posts
    1,048
    Central Kentucky
    Tractorless :(
    I expect there will be a few storm shelters built after what went through there a few weeks ago. One fellow at work couldn't contact his parents, so he went out there and their house was simply gone. He followed the trail of debris and found his father wrapped around a tree. A guy shouldn't have to find his family that way. Sad Sad situation.
    Ian
    Everlast PowerArc200
  8. #1778
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,001
    Rochester, MN
    Kubota BX2230
    Quote Originally Posted by JohnDeere4300 View Post
    That doesn't sound like a great place for a shelter. What if it's full of water when you need it most?
  9. #1779
    Elite Member
    Join Date
    Feb 2012
    Posts
    4,014
    NE Indiana
    1710 Ford, Versatile 150
    I am always amazed at what my little Ford will do. Today I was cleaning up and area that had become overgrown. I used the chain saw on a few of the bigger trees but anything 3" of below I just ran over and let the Bush Hog take care of them. I just can't believe what 28 hp on a 5' Bush hog can do!
    Then because it was so nice I started planting garden. Potatoes on St. patrick's day!
  10. #1780
    Join Date
    Feb 2005
    Posts
    1,565
    John Deere 4300
    Quote Originally Posted by RaydaKub View Post
    That's what I thought too, and I asked him the same question!.... But he said it should be/stay dry after the concrete is poured...(I say the water will find a crack somewhere)
    All I'm doing is digging the hole, and then I'm out of there!!!
    He bought some treated 2x4's & 3/4'' plywood $$... He's going to frame it all up with the 2x4's, Then screw the plywood to the 2x4's with it standing up 7FT. high..(he cut 1FT. off each sheet)
    Then (some way) lift the whole thing up and set it down in the hole... Then fill in with concrete between the clay dirt and plywood, and pour concrete down in it for the floor..(I still believe it will leak)... He said he plans to leave the plywood down in there... I can't explain to you how he plans to build the top of it!
    But I can't understand why he bought 3/4'' treated plywood!... If it was me, I would have used 7/16'' OSB to use to hold the concrete.... He could have saved A LOT of money!!
    But what do I know... I'm just a Backhoe operator!!!
    Bill
    John 3:16
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
