Ron JD670
- Joined
- Jan 20, 2012
- Messages
- 154
- Location
- Jacksonville in S. Oregon
- Tractor
- for Cristmas 2011 found used Joh Deere 670 w/ 40 hrs and options
Yesterday I finally, with some reservation, took another shot at improving the drainage on my 200' of a shared road. I started a couple weeks ago with my almost new box blade but my top link was to short and separated. I have a solid road base and have only had to add gravel once in 10 year and it is on an even grade, did not want to mess it up. But, my neighbors above refuse to agree on ditching their portion and water runs right onto my portion. The wheel ruts are starting to carry more water on down washing out my other neighbors road and my exit route. I don't want to just keep adding gravel.
With new longer top link in place I First cleaned out the old ditch on the left side. Had to dump box full of dirty grass and gravel about every 25 ' used the FEL to move them out of the way then made a clean up run.
Went after the right side ditch with my FEL and tooth bar because it was to rough and bumpy and angled to try the box blade. I was working across the road but when I backed up with my first bucket full of dirt I hung the BB up on the berm behind me because I had cleaned out the left ditch first. Wasn't a problem before. Got more BB practice taking down the berm about six inches. Will need to go back after the Right ditch with a rear blade or the FEL without the tooth bar to clean it up.
Next knocked down the out side of the ruts on both sides moving material back to the middle and filling in the ruts so it would drain into the improved ditches took a couple careful passes down the middle to move that gravel into the ruts, but still leave a little crown.
Stopped there before I created a problem. I'll see how things settle in over the next week. Feel pretty good about my first two hours of road work.
Good seat time and another lesson learned.
Lookout for the Easter Bunny
RoN
RoN
