Page 187 of 838 FirstFirst ... 87137177184185186187188189190197237287687 ... LastLast
Results 1,861 to 1,870 of 8375
  1. #1861
    Super Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar (For Sale), CS261, & FS190 + Echo CS400 & rusty old Ranger snowplow truck
    Default Re: TODAYS SEAT TIME
    I forgot! I also ground two stumps out of the front yard. both had invasive surface roots I had to grind also.
    Very rewarding!
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, Titan 48" Pallet Forks, & more to come. & 2003 JD LX266 42" deck mower.
    Managing 51 Acres of Virginia hills with ponds & streams, Freshly replanted Loblolly!, riding trails, empty pasture, long gravel drive, garden, & yard.
  2. #1862
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,963
    Pennsylvania
    Kubota BX25
    Quote Originally Posted by Creamer View Post
    I am thinking about 3000 lbs. Wouldn't put in my half ton but not a problem for my 350.
    Quote Originally Posted by Gordon Gould View Post
    Man - Thats a pretty good guess.
    You got me curious so I went out and measured it. It has a pretty regular shape and easy to figure. I got 16 cubic feet. Solid granite is 168 lb per cu ft which gives 2688 lbs.
    That's a BIG rock...
    No way I could move that with the BX.
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
  3. #1863
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,009
    Rochester, MN
    Kubota BX2230
    Quote Originally Posted by CompactTractorFan View Post
    Aw come on. You never know until you try it! See what kinda guts it has!
  4. #1864
    Join Date
    Nov 2010
    Posts
    1,048
    Central Kentucky
    Tractorless :(
    Yep, you'd see it's guts spewed all over the place... LOL
    Ian
    Everlast PowerArc200
  5. #1865
    Silver Member jonnyc1999's Avatar
    Join Date
    Nov 2010
    Posts
    177
    New Kent, VA
    Craftsman GT5000
    This weekend was catch up time. I FINALLY got around to pulling the downed trees out of the woods that dropped across my driveway during the hurricane in August. I'm going to mill the poplar logs into 1x6's with my chainsaw mill and use it for interior siding in my shed.
    I also moved my latest Jeep project to the back part of my property. It was going to be a quick and dirty rebuild until the engine shop told me that practically everything in the "recently rebuilt" engine needed to be replaced. So much for trusting a sellers word!
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-tractor1-jpg   TODAYS SEAT TIME-tractor2-jpg   TODAYS SEAT TIME-tractor3-jpg   TODAYS SEAT TIME-tractor-jeep-jpg
  6. #1866
    Join Date
    Jul 2010
    Posts
    7,963
    Pennsylvania
    Kubota BX25
    Quote Originally Posted by RaydaKub View Post
    No thanks...this one was big enough for me:
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-tractor-stuff-123-jpg
  7. #1867
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    I got about 4 hours today. I moved some tree lenght pine logs that Jonnyc1999 cut down for me after my accident in Nov. 11. I also moved some more of my bucked logs to my new cutting location/setup. I also started buolding 3 different burn piles. Then most of the time I played with the ratchet rake, bucket, and grapple (I switched them around a few times) as I'm trying to make the NEXT pasture area ready. I basically was "sweeping" the debris with the RR, and then I tried using the bucket to get rid of the piles and it wirked OK, but I switched back to the grapple and largely due to the large percentage of fibrous wood in these piles, the grapple is actually superior to the bucket in hauling this "dirt" 9 times out of 10. the 10th was a bumpy trip and too much fell out an that load was a waste.
    I also waded into the serious slash pile and would back drag with the teeth of the grapple a couple feet and grab whatever I could and haul it off to the burn pile.
    I also used the grapple to pop out the nasty welded chain mailbox post, and put in a new pretty post and XL Mailbox that I built.
    It was a good day of Birthday seat time (I took the day off from work).
    Be well all!
    David
  8. #1868
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,343
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by MossflowerWoods View Post
    Be well all!
    David
    Looks like you have been having fun and getting a lot done too David. Looks like it will rain here off and on for another week, so not much tractoring gonna happen here.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  9. #1869
    Join Date
    Apr 2011
    Posts
    149
    Central Massachusetts
    L3800 HST
    David,
    I notice you didn't include the time you spent doing your 50 hour service, does that mean what I think it does?
    L3800 HST, Landpride 72" rotary cutter, Wallenstein BX42 chipper, FEL, BH77, 42" pallet forks
  10. #1870
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Quote Originally Posted by k0ua View Post
    James K0UA
    James,
    I also ground 3 stumps in the pasture area that were bouncing me around as I was using the RR...
    It started raining as I got to the coffee pot this morning. 90% chance of T-storms today, cool and raining all weekend, then May looks like rain every day next week.
    Glad I tractored yesterday...
    Seems we might be in the same boat sir.
    David
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
