Page 190 of 261 FirstFirst ... 90140180187188189190191192193200240 ... LastLast
Results 1,891 to 1,900 of 2607
  1. #1891
    Elite Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    4,923
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar, & FS190
    Default Re: TODAYS SEAT TIME
    Quote Originally Posted by lstinthot View Post
    My trailer is wide enough to hold some of that good stuff. I have a sawzall as well I can lend for compost. We are in need of some stuff to jump start our garden efforts. Let me know when a good time to swing by is.
    Mike
    Quote Originally Posted by jonnyc1999 View Post
    Hey David, my sawzall is corded. I'm off all weekend and the first part of next week, so maybe we can get some work done
    Mike and Jon,
    Please plan to come by Saturday, we can set you up for as much "compost" as we can collect... I am running behind on my garden project (and all my projects).
    I will happily take the assistance with the sawzall to cut the opening to my "Barn" bigger to accomodate the ROPS/Canopy...
    I'm not leaving for Oregon until Monday (I think).
    Of course I was PLANNING to go get a load of hay this afternoon, I need to pickup two loads at least, probably 65-75 bales total (maybe 3 loads) because my Hay supplier needs the space for the new crop (I've offered working the harvest with him, he seems open to that). The rain is 40-50% this afternoon, so looks like today will not work for a load of hay.
    The "barn" is ready for hay storage with pallets set up across the entire back section, should be able to store over 100 bales (depending on how high I stack them). Biggest concern is that it is very dry clay dirt floor which generates lots of dust.
    I am getting VERY close to the next pasture fence project. I'm planning to do the end closest to the house, the curved part, so that will be slightly more complex... Maybe by the end of the month?
    The world seems a bit wobbly at the moment.
    Be well all,
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, & more to come. Mowers 2003 JD LX266 42" deck mower, & old JD STX-38 (12.5 hp).
    Managing 51 Acres of Virginia hills with ponds & streams, mature market timber, riding trails, horse pasture, long gravel drive, veggie garden, & yard.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #1892
    Gold Member catdozer's Avatar
    Join Date
    Sep 2011
    Posts
    458
    Indiana
    Bobcat CT235
    Default
    Got plenty if seat time today, almost 3 hours, going along ditches and doing the trails! I really like my setup on my brush hog, I don't miss the pull type at all! Heres a few photos from today!
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-image-3422786866.jpg   TODAYS SEAT TIME-image-1867463272.jpg   TODAYS SEAT TIME-image-2929440153.jpg   TODAYS SEAT TIME-image-2367944507.jpg   TODAYS SEAT TIME-image-409474437.jpg
    Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
  4. #1893
    Join Date
    Feb 2012
    Posts
    607
    Staunton, VA
    John Deere 3038E
    Going to put my wife in the seat today and use a chain - rigged by me - to pull out a lot of old, twisted fence wire. Sometimes I can pull it out intact, sometimes the tractor balks, so I slack it off and use old bolt-cutters to cut the wire off trees and the like. Going to be hot, so should be fun...
  5. #1894
    Join Date
    Apr 2012
    Posts
    113
    Syracuse, NY
    JD 4410
    Default
    Only took about 20 minutes, but I moved 2 bucket loads of rotted horse manure from the pasture closer to the flower garden. Luckily someone else will be speeding it into the garden, I had the easy job!
  6. #1895
    Join Date
    Apr 2011
    Posts
    78
    Forest Ranch, CA
    Kubota L3540
    This is from a few weeks ago, but just got around to getting the pics off the camera and posting.
    The backhoe sure makes chainsaw work easier! After cutting the tree down (it was damaged from an early snow last year) I tried to drag it out of the woods, but no go. Had to cut it in half first. These pics are when I am about 3/4 done bucking the first half. The backhoe could not lift the entire log, so I had to cut some off, then raise it up, cut some more off, etc... Used the backhoe to load the rounds into the trailer - why not, I was having fun. Had to unload the trailer by hand and oh boy were those suckers heavy! Made me appreciate the back saving work by the tractor.
    -Jeff
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-img_2499.jpg   TODAYS SEAT TIME-img_2500.jpg
    Kubota L3540 HST-3, LA724 Loader w/ 3rd function valve & quick attach bucket, BH77 Backhoe, 72" Box Blade, 84" Quick Attach FEL Snow Blade, 48" NAI Grapple
    Located 3200 feet elevation in the Sierra Nevada foothills of Northern California
  7. #1896
    Gold Member mpham's Avatar
    Join Date
    Oct 2011
    Posts
    289
    Massachusetts
    Kioti ck20
    Got two hours in today knocking over a tree, popping the stump and picking up the roots. A CK20 with a flat bucket is not very good at this job..
    Phil. from Mass.
    2008 Kioti ck20 with 380 hours
    New to me 2011 K120 loader
  8. #1897
    Join Date
    Aug 2011
    Posts
    4,923
    Ladysmith, VA
    Not really seat time, did not use the tractor at all, but I went and picked up 47 bales of Horse Hay today and stacked them in my "barn".
    I've got at least 33 more to pick up tomorrow, and then he is giing me the "dirty" bales off the bottom. so that will be about 30+ bales I need to get tomorrow also. I've got to finish it all tomorrow, Sunday my oldest daughter is confirmed at Church, and Monday I fly off to my brother's funeral etc. in Oregon.
    1st pic is my "barn" with the stacked hay. 2nd pic is my "helper"...
    Be well all,
    David
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-2012-05-04-16.46.28.jpg   TODAYS SEAT TIME-2012-05-04-13.39.04.jpg
  9. #1898
    Join Date
    Jan 2012
    Posts
    219
    Brookshire TEXAS
    LS R4047
    Default
    played with the backhoe today, I'm thinkin I'll be getting a grapple soon. I'm also starting to design a ripper for the backhoe
    y'all have a good day
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  10. #1899
    Join Date
    Aug 2011
    Posts
    4,923
    Ladysmith, VA
    I got an hour or 90 mins of seat time today.
    I dropped the TSG-50 and connected the drawbar foir the very first time.
    I hauled my flatbed trailer full of hay down to the "barn" twice. The tractor road was still wet from the daily t-storms and the mud was slimy sticky and STINKY(Holy cow it smelled like cowpies!!!)
    Now my tires stink! Back to the story... We moved at least 30 bales of good horse hay, and at least 45 bales of "dirty" bottom row bales. I now have 2large hay stacks in the "barn". I dumped one broken dirty bale into the pasture as "mulch".
    Then I dropped the grapple and got the bucket (minus the ratchet rakel) and loaded 3 buckets of horse/bird "compost" into the back of Jonnyc1999's F-150. Plus 4 dirty bales for archery practice (We want PIX Jon!). Then Jon got out a sawzall and he quickly cut out a section of the opening for the "barn" (we used my bucket as a Jon Lift) and suddenly my tractor could park INSIDE for the first time ever (but I left it outside in the rain because the tires STINK!!!)
    I am ever so thankful to my buddies from Church and Jon from TBN who came and helped me put up some serious hay before my trip on Monday.
    I also got about 30 min running the JD LX266 with the 4' York (yorkie?) Rake and I did a minor groom of the entrance of the driveway and I also raked the horse apples to break them up and scatter them...
    Finally, I used a shovel and wheelbarrow and cleaned up the "river bed" I previously cut with the FEL & bucket and when done we busted through deeper into the pond and let the river "flow". It burbled nicely. I'm ready to start lining it with rocks next weekend...
    The dirt we moved we dumped into the low spots of the tractor road... Hopefully it stinks less with new mud...
    Be well all,
    David
    It was a great day.
  11. #1900
    Veteran Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    Kubota L3010DT, Dresser TD7G Dozer
    Serviced the JD lawn tractor. Also I had decided to replace the traction belt this year but there were no instructions or even a part number in the manual for the traction belt. Replacing the belt turned out to be a much bigger challange than I thought it would be for what I consider a maintenance item. I figured out why it was not in the manual ... There is no way they could have described how to do it without using cuss words.
    Then I mowed the front lawn for the first time this season after I got the tractor back together.
    "If you're not making any mistakes then you're not doing anything"
    L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
