Results 2,181 to 2,190 of 2570
09-16-2012, 10:49 AM #2181Veteran Member
- Join Date
- Nov 2010
- Posts
- 1,307
- Location
- Buckner MO
- Tractor
- 2005 Kubota L5030 GST; Farmall 706
Shall we call you Dr. NCNurseryman??
Originally Posted by ncnurseryman
#sundaymorninghumor
Dean
"Get busy living, or get busy dying" - Morgan Freeman in "The Shawshank Redemption"
09-16-2012, 11:05 AM #2182Veteran Member
- Join Date
- Jun 2010
- Posts
- 1,063
- Location
- Somewhere north of Roseau,MN
- Tractor
- Fordson Major Diesel, Ford 1510, John Deere L111
Re: TODAYS SEAT TIME
Ford 1510
Du-Al 105 Loader
"The Thumb" Grapple
Bush Hog RBC60 Rear Blade
Woods HC54 Rotary Cutter
Tarter 5' Heavy-Duty Hinge Back Box Blade
Buhler Farm King Y600 Snowblower
09-16-2012, 12:18 PM #2183
Yes, that all sounds good to me. now, if I could just get the income that comes with those titles I could get more toys.
09-16-2012, 07:21 PM #2184
This is what I did all today, over 6 loads and 4 hours on the tractor and Gator. Had the T190 unloading. So gator was pulling the trailer and took 4wd just to get it moving. Had to put 350lbs in the back to pull it up some hills for traction. Tomorrow night get to start hauling the good trees to sell.
Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
09-16-2012, 07:43 PM #2185
nothing exciting here....bushhogged 2 acres of over growth, and pulled our ZTR out of the mudhole where my wife got it stuck
the bucket hooks finally came in handy!
Proverbs 31:6-7
Lord, help me to be the kind of person my kudzu thinks I am.
09-17-2012, 08:04 PM #2186Platinum Member
- Join Date
- Nov 2005
- Posts
- 652
- Location
- Southwestern, PA
- Tractor
- 1958 Ford 961 Powermaster
Deleted for double post.
Kubota L5240 with loader and backhoe
1958 Ford 961 Powermaster LP
09-17-2012, 08:09 PM #2187Platinum Member
- Join Date
- Nov 2005
- Posts
- 652
- Location
- Southwestern, PA
- Tractor
Saturday I used the 961 to brush hog about 4 acres and the used the 5240 to finish mow about 3 acres. Dropped the finish mower and hooked up the box blade to fix up my driveway which was a little washed out from some recent heavy rains. Unfortunately no pictures but a great Saturday.
09-17-2012, 09:47 PM #2188Super Star Member
- Join Date
- Oct 2004
- Posts
- 16,843
- Location
- First organized permanent settlement in the northwest territory
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
The only seat time I got today was driving the pick up to town to get a new battry for the BX23 so I can get some seat time on it later.
09-17-2012, 10:36 PM #2189Veteran Member
- Join Date
- Sep 2008
- Posts
- 1,382
- Location
- Central MA, Lakes Region NH
- Tractor
- Kubota L4610 and John Deere 410
Changed out half the teeth on my stumpgrinder today and decided to try it out on an old stump. I started grinding and about 3/4 of the way through I stalled the tractor. I didn't realize it at first but I ran completely dry! I was out of fuel. I guess I was a but lower than I thought and that grinder eats up the fuel. I decided it was quitting time anyways since the wife had a fresh apple crisp ready to be devoured.
I'll go get fuel tomorrow.Kubota L4610 and John Deere 410 - WR Long 64" Grapple (best attachment ever!) QA front forks, rear forks, Brown 472 HD Rotary Mower, homemade 3 pt log splitter, Land Pride rake/blade combo, Land Pride HRL 3578 box blade (Hydro scarifiers), Shaver SC50 3 pt. Stumpgrinder, FitRiteHydraulics TnT, 6" Vermeer PTO Chipper (Hydro feed), 2 bottom Disc Plow, Ratchet Rake
Rear Remotes Install
How to search TBN
09-20-2012, 07:55 PM #2190Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
We had a section of driveway whose surface was getting thin and it was hard to grade because the road bed rock was showing thru here and there. I put a skim coat of 3/4 Sta-mat on it. It took ten loads with my 2001 Ram 3500 Dump. 35 ton total over 750 feet of driveway. There is a good size Pike Industries crusher plant two miles down the road that I haul from. We are really lucky that they welcome guys like me with small trucks making many trips as customers. They are very community orientated.
I tailgate spread the gravel then went over it with the land plane grader blade to finish it off."If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
