Page 220 of 261 FirstFirst ... 120170210217218219220221222223230 ... LastLast
Results 2,191 to 2,200 of 2607
  1. #2191
    Gold Member ncnurseryman's Avatar
    Join Date
    Jan 2012
    Posts
    282
    In the Piedmont, NC
    John Deere 970
    Default
    Nice looking driveway. I need to get some rock myself. The quarry is about a mile down the road so its convenient, but you can sure hear the dynamite some days. This morning used the fel to pull two orders of ruby loropetlums and big leylands. Got to love a fel.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2192
    Elite Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    4,923
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar, & FS190
    Default Re: TODAYS SEAT TIME
    Saturday I got a couple hours of seat time bush hogging. I finished up the section that will be the "South Pasture" and much of the sloped area that will eventually be in the "North Pasture". I am still very nervous and careful on slopes. Mostly I try to only go straight up & down, always in 4wd with all implements don low.
    I also ran most of a tank of gas on my Stihl FS90 with the metal "Brush Blade" WOW! This was the first time I ever used the metal blade and it was AMAZING! I was clearing brush like never before!. I'm going to be using it to clear some trails VERY soon and VERY often!
    Be well all.
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, & more to come. Mowers 2003 JD LX266 42" deck mower, & old JD STX-38 (12.5 hp).
    Managing 51 Acres of Virginia hills with ponds & streams, mature market timber, riding trails, horse pasture, long gravel drive, veggie garden, & yard.
  4. #2193
    Join Date
    Aug 2011
    Posts
    4,923
    Ladysmith, VA
    Be well all.
    David
  5. #2194
    Platinum Member sparc's Avatar
    Join Date
    Oct 2011
    Posts
    750
    NJ
    Ford 2600, NH TC-25, Bobcat M610, JD X534, DigIt Model 158
    Quote Originally Posted by Gordon Gould View Post
    We had a section of driveway whose surface was getting thin and it was hard to grade because the road bed rock was showing thru here and there. I put a skim coat of 3/4 Sta-mat on it. It took ten loads with my 2001 Ram 3500 Dump. 35 ton total over 750 feet of driveway. There is a good size Pike Industries crusher plant two miles down the road that I haul from. We are really lucky that they welcome guys like me with small trucks making many trips as customers. They are very community orientated. I tailgate spread the gravel then went over it with the land plane grader blade to finish it off.
    Nice work on the driveway. Did you build that land plane?
    I'd like to build something similar if I can't find one at a decent price.
    Heading over to the auction near New Holland, PA tomorrow to see what's available.
  6. #2195
    Veteran Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    Kubota L3010DT, Dresser TD7G Dozer
    Quote Originally Posted by sparc View Post
    Thanks - land plane grader makes it easy. Yes it is homemade. A picture before paint and cutting edges.
    "If you're not making any mistakes then you're not doing anything"
    L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  7. #2196
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    1,053
    Rochester, MN
    Kubota BX2230
    I spent about and hour and 1/2 running over to my neighbor's place and back. He had a large black walnut tree come down a little over a year ago. He cut it up into large logs. I asked him what he was going to do with it. If we could find a sawmill around somewhere, they might get some nice boards out of it. The trunk is very straight. There were 2 chunks about 16 inches across and 20 inches high, plus 4 logs all about a foot across and 8-9 feet long, plus 4 smaller logs also 8-9 feet long. He gave up on finding anybody and gave it to me just to get rid of it. I've got a few calls to make to see if anybody can make use of it, but otherwise it's firewood. I made 5 trips over and back and need to make 3 more. The big logs were heavy enough that my tires were starting to squat. Granted they are the turfs, but I have them pumped up to the max. I guess the logs are fairly heavy.
  8. #2197
    Silver Member joeyd's Avatar
    Join Date
    Jul 2010
    Posts
    192
    North Idaho
    TYM 353HST
    I spent 3 hours spreading 3/4" crush around my pole barn and over a new fill area that we did yesterday. Some of todays time was knocking down loads of top soil that I have to put over my septic field. My friend who is doing the hauling with his dump truck needed the loads knocked down since there is limited access to the drain field and he needs a level area to dump in. Tomorrow he will bring another load and his dozer to spread it and put a nice grade on it to shed normal run off.
    Isa 43:2-3
  9. #2198
    Join Date
    Apr 2011
    Posts
    127
    West Gardiner, Maine
    Kubota BX 23
    Couple hours today rigging and then moving an 8x8 shed. Dragged it about 60ft across back yard but the hardest part was getting it up over 3ft high stone wall. Will finish up tomorrow leveling and geting up on cement blocks.
  10. #2199
    Veteran Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    1,546
    Central MA, Lakes Region NH
    Kubota L4610 and John Deere 410
    Quote Originally Posted by RaydaKub View Post
    Why can't you live closer I'd mill that up for ya!
    Kubota L4610 and John Deere 410 - WR Long 64" Grapple (best attachment ever!) QA front forks, rear forks, Brown 472 HD Rotary Mower, homemade 3 pt log splitter, Land Pride rake/blade combo, Land Pride HRL 3578 box blade (Hydro scarifiers), Shaver SC50 3 pt. Stumpgrinder, FitRiteHydraulics TnT, 6" Vermeer PTO Chipper (Hydro feed), 2 bottom Disc Plow, Ratchet Rake
    Rear Remotes Install
    How to search TBN
  11. #2200
    Join Date
    Sep 2008
    Posts
    1,546
    Gordon,
    I copied your pic in a post I have about land plane's. I'd love to build one someday and keep that thread handy for 'notes'. I'd love to know more about your land plane, such as steel thickness, weight, size or anything you feel like sharing. I've always admired how well that came out. Yours and Jenkins are two that I want to copy when I build one. Well, if you don't mind anyways.
    How to search TBN
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
