Results 2,201 to 2,210 of 2607
09-28-2012, 07:34 AM #2201Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,676
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
Re: TODAYS SEAT TIME
Actually I have a hard time believing how good they work. Here are some notes I had on it. Hope it helps. Steve's units are excellant you are smart to look at them too.
Grader 4'-6" long, 5' wide ( inside) 575 lbs
Notes
Lift Arm Braces 28" center to center
Upper Cross Braces 2' apart
Blade Mounts 2' apart, first blade mounted 10" back, front of Blade Mounts are 3/4" below runners
3" X 3" triangles cut from bottom corners of sides for runner angles
1/2" Grade 8 bolts and extra long nuts for tail gate stop pins
swinging tailgate up and forward to hang insde against stops is like box blade ( sort of )
swinging tailgate up and back to hang behind stops allows use like push blade in reverse
Steel
Standard lengths - Bought and picked up at steel supply house, They make one cut at no charge
3/8" X 12" steel plate 20' (2/10') $210
2 sides, 6pcs 6" X 3" for hitch clevises, tail gate
3/8" X 2" steel bar 10' $25
2 runners
2 1/2" X 1/4" Square tube 24' (2/12') $115
2 upper cross members, top link verticle and angle braces, 2 lift arm braces
4" X 4" X 3/8" angle 10' $69
2 cutting blade mounts
1 1/2" schedule 80 blk iron pipe 10' $46
hinge pin for tail gate ( used 3 short pieces of 2" sched 40 I had for hinges )
Total Steel $465
Figure on another $250 or so for a pair of heavy duty cutting edges.
-------------------------------------Last edited by Gordon Gould; 09-28-2012 at 07:50 AM.
"If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
09-28-2012 07:34 AM # ADS
09-28-2012, 08:00 AM #2202
Well, I suppose I could load one up and drive over. Then drive back and get the 2nd one. 8mph and 1,000 miles or so. No sweat! Thanks for the offer!
Originally Posted by Piston
09-28-2012, 09:13 AM #2203Veteran Member
- Join Date
- Sep 2008
- Posts
- 1,546
- Location
- Central MA, Lakes Region NH
- Tractor
- Kubota L4610 and John Deere 410
WOW! Thanks Gordon! That's very helpful!
I copied your info on my land plane thread http://www.tractorbynet.com/forums/a...-leveling.htmlKubota L4610 and John Deere 410 - WR Long 64" Grapple (best attachment ever!) QA front forks, rear forks, Brown 472 HD Rotary Mower, homemade 3 pt log splitter, Land Pride rake/blade combo, Land Pride HRL 3578 box blade (Hydro scarifiers), Shaver SC50 3 pt. Stumpgrinder, FitRiteHydraulics TnT, 6" Vermeer PTO Chipper (Hydro feed), 2 bottom Disc Plow, Ratchet Rake
Rear Remotes Install
How to search TBN
09-29-2012, 08:01 AM #2204
Actually this was yesterday, but the fel blew a hose, the one attached to the cylinder. After several attempts to remove it, (it was really stuck) I just took the whole cylinder off and took it down to the jd dealer and they fixed it right up. Put the cylinder back on, reatttached the hose and now the old girl is back online.
09-30-2012, 09:26 PM #2205Platinum Member
- Join Date
- Oct 2011
- Posts
- 750
- Location
- NJ
- Tractor
- Ford 2600, NH TC-25, Bobcat M610, JD X534, DigIt Model 158
De-sodded an area roughly 30' x 70' for some covered space to store tractor, attachments, and trailers under.
Now I am thinking I should (or could) strip off the top soil and set it aside for use elsewhere.
Then after the shed is up lay some non-weaved geotextile down and cover with some 3/4" crushed stone.
09-30-2012, 09:26 PM #2206Platinum Member
- Join Date
- Oct 2011
- Posts
- 750
- Location
- NJ
- Tractor
09-30-2012, 10:17 PM #2207
True "seat" time today. Never started the tractor at all. But I spent about 2 1/2 hours stretching and gluing the side of my seat cover back down to the metal pan. I was able to stretch it far enough to wrap it around the metal. I used 3 vice grips to hold sections in place while the glue set. Then I glued the edge material all along the seat vinyl. Thanks to Roy Jackson for suggesting Gorilla Glue brand super glue. Hopefully it holds a good long while.
10-01-2012, 06:26 AM #2208Elite Member
- Join Date
- Aug 2011
- Posts
- 4,922
- Location
- Ladysmith, VA
- Tractor
- Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar, & FS190
Yesterday I managed to get a short bit of seat time in. I ground 6 stumps in the next pasture area, then I drove the tractor down to the hay barn where I parked it inside (the grapple is out the door a bit so mostly inside) next to the hay. It is gonna rain the next couple days. This is only the 2nd time I've parked it inside in over a year.
Be well,
DavidFormer Submariner & Army SGT
2011 Kioti
DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, & more to come. Mowers 2003 JD LX266 42" deck mower, & old JD STX-38 (12.5 hp).
Managing 51 Acres of Virginia hills with ponds & streams, mature market timber, riding trails, horse pasture, long gravel drive, veggie garden, & yard.
10-01-2012, 06:26 AM #2209Elite Member
- Join Date
- Aug 2011
- Posts
- 4,922
- Location
- Ladysmith, VA
- Tractor
Be well,
2011 Kioti
10-06-2012, 05:29 PM #2210Super Star Member
- Join Date
- Oct 2004
- Posts
- 16,849
- Location
- First organized permanent settlement in the northwest territory
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
I'd mill that up for ya!
