Page 223 of 261 FirstFirst ... 123173213220221222223224225226233 ... LastLast
Results 2,221 to 2,230 of 2607
  1. #2221
    Veteran Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    Kubota L3010DT, Dresser TD7G Dozer
    Default Re: TODAYS SEAT TIME
    Quote Originally Posted by Otto Syracuse View Post
    Hard to tell in the photo......is that fir or beech?
    Balsam Fir. Took the photos after I limbed it. Here is a truck load of the stuff.
    "If you're not making any mistakes then you're not doing anything"
    L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2222
    Join Date
    Apr 2012
    Posts
    113
    Syracuse, NY
    JD 4410
    Default
    Quote Originally Posted by Gordon Gould
    Well, that's a nice load of wood! Nice work!
  4. #2223
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,110
    KY @ TN line
    2011 LS R3039
    That's a good load.
  5. #2224
    Silver Member lstinthot's Avatar
    Join Date
    Sep 2011
    Posts
    139
    Spotsylvania, VA
    CT230
    Had the tractor over a friends house helping remove some roots around his drainfield. Battery died while I was there. Ended up putting it on the charger for a while and it finished the day. Checked voltage on battery when I got it home and it was only 11.2V with the tractor running. Figures something would happen, Bobcat's warranty is only 1 year, I have owned it 1 year and 1 week. Called to price the parts to replace it myself and got put on hold long enough I just hung up. Went back out to trouble shoot some more and found the wire going to the alternator had come loose in its connector. Snapped back together and all is good now.
    We ended up digging all around the distribution box of the drain field to break up all the roots in the area. Had to pull a lot of them out of the lines too. Lines were getting plugged but we were able to work them all out and all the lines are flowing good again. Good thing we caught this early, could have been very costly if the roots had gotten too far in the lines.
    CT230 with backhoe attachment. 84" rake, bucket bite on FEL.
  6. #2225
    Join Date
    Sep 2011
    Posts
    139
    Spotsylvania, VA
    CT230
  7. #2226
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,849
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Got about 3 hours on the BX23.
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  8. #2227
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    A few photos from today. The second one was a long winch. You can bearly see the tractor thru the slash. A perfect day to work in the woods
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-p1060083.jpg   TODAYS SEAT TIME-p1060094.jpg   TODAYS SEAT TIME-p1060109.jpg   TODAYS SEAT TIME-p1060118.jpg
  9. #2228
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I used the B 26 to dig up a 60 foot tall pine tree that was growing between two larger trees. Had to chain saw a couple of roots then hook 2-25 foot chains and a 20 foot tow strap together to pull it over. I tied the chain as high as I could on the tree by standing in my RTV 900. I tried to pull it with the RTV but couldnt so I hooked on the B26 and pulled it over. It was about 10 feet shy of my tractor when it toppled. It was held up in the air about 10 feet and had to work it with the hoe to get that last bit of trunk severed. Then I used the fel to drag it out of the hole and backfill it. Got about 1/2 hour doing that and then on the way back to the house I decided to finish off grading a ditch to smooth the banks so I could mow without turning the lawn mower over. I had fixed all of it but about 15 feet previously so I was just finishing up a previous project.
    None tractor work was removing some electric fencing that we had put up during the drought to graze some of the yard grass rather than mowing it. Pasture grass got pretty lean before the arrival of T.S. Ivan which gave us 1.5" which was first rain since 1st of May.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  10. #2229
    Silver Member Poncho's Avatar
    Join Date
    Mar 2004
    Posts
    229
    Tallahassee Florida
    Massey Ferguson 431
    well... last weekend I put about 8 hours in the seat on the hunt lease cutting roads, shooting lanes and food plots. After that the next morning did a bunch of landscaping and wound up over-straining the back the worst I've ever experienced.... percocet and muscle relaxers for the last week. Lesson learned next year don't try to do the hunt lease all in one day... too much banging around going over wind rows and un-even terrain. what really hurts is the big 5-0 is in a couple weeks... and I've been hearing it from lots of folks
  11. #2230
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    Quote Originally Posted by Poncho View Post
    Glad you got the work done but sorry about the back. That is a hard lesson to learn especially when hunting has top priority. Don't ask how I know and don't get back at it to soon. It actually goes better for me now that I am retired. I can do a little every day. I think that is better
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
