Results 2,311 to 2,320 of 2575
12-23-2012, 07:35 PM #2311Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
Re: TODAYS SEAT TIME
"If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
12-23-2012, 07:57 PM #2312Silver Member
- Join Date
- Apr 2012
- Posts
- 109
- Location
- Syracuse, NY
- Tractor
- JD 4410
Does running you tractor for 20 minutes count as seat time? Well, that's all I did, so it'll have to for a while. Started right up and ran smooth as silk, I love the sound of diesel engines.
12-23-2012, 10:31 PM #2313Silver Member
- Join Date
- Sep 2011
- Posts
- 106
- Location
- North Carolina
- Tractor
- Kubota B7800
Couple hours spreading sand down the driveway , 10 mins. covering up the fox , a few more hours mowing the small trees on the property line to define the line . Just keeping things easy to define. This is relaxing for me.
12-23-2012, 10:49 PM #2314Gold Member
- Join Date
- Jul 2012
- Posts
- 318
- Location
- West Granby CT
- Tractor
- JD 4105. 375 Backhoe. 2005 Polaris Ranger
Send a bunch hours wrapping Christmas gifts. First time EVER I have finished before Christmas Eve late night. This will free me up to drag some down trees out of woods with tractor. Weather is good. Ground frozen with only a dusting of snow. Should be easy dragging.
12-23-2012, 11:03 PM #2315
I went ahead and used the landscape rake pull of all the little branches off the drive and used the landplane to touch up the drive. Smooth as silk for plowing now. Also took the T190 and cut some new trails on some frozen swamp ground
Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
12-24-2012, 12:09 AM #2316
Hehehe! Welcome back, Fellas!
12-25-2012, 12:46 PM #2317Veteran Member
- Join Date
- Dec 2007
- Posts
- 2,428
- Location
- texas
- Tractor
- MX5100 HST W/844 FEL
my brother has been getting alot of time doing the fall shredding.i havent got on the tractor in awhile.but ill get on it as soon as spring gets here.
12-25-2012, 04:47 PM #2318
I moved some wood to the garage yesterday, along with the tractor and the rear blade. Local weather has my part of Indiana under a winter weather warning. They are calling for 5-12 inches of snow, with high winds. So maybe when I get home from work tomorrow I will have some snow to move.
2012 JD 2320
200cx FEL 61" Bucket
62D MMM
60" King Kutter Rear Blade
King Kutter Middle Buster
5' County Line Box Blade
Home made 3PH trailer mover
Home Made Drag
12-26-2012, 07:48 PM #2319
Today I got seat time and got to use all of the following tools:
3/4 inch wrench
11/16th wrench
2000w generator
LED shop light
Grease gun
Hacksaw
Pliers
Ball peen hammer
Large flathead screwdriver
Anyone want to guess what I did today and why I needed all those tool?Kubota BX2360, 54" Fine Cut MMM, LA243 FEL, BX2789 Rear Snow Thrower
12-27-2012, 10:14 AM #2320Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
In the dark too
