Page 242 of 823 FirstFirst ... 142192232239240241242243244245252292342742 ... LastLast
Results 2,411 to 2,420 of 8224
  1. #2411
    Platinum Member High Compression's Avatar
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Kubota L5740-3/ Kubota ZD21 pro60
    Default Re: TODAYS SEAT TIME
    Well, I just spent 6 hrs bouncing around 126 acres of pasture, pulling a fertilizer buggy with my L5740. I need 4shorts air ride seat.!
    "It is better to be thought a fool, than to open your mouth and prove it."
  2. #2412
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,599
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    Quote Originally Posted by Piston View Post
    Yesterday I tore up my kitchen tile (along with gutting my whole kitchen) and brought the tractor up next to the house, raised the bucket up level with the window, and filled the bucket with demo'd tile. Then I'd go dump it in the "bagster" about 40' away and return for another load. All in all not much seat time but sure saved a lot of work.
    It was nice to use the bucket again, it mostly just sits and rusts ever since I got the grapple a few years ago.
    I am really surprized you didn't use your grapple to gut the kitchen
    Sorry - couldn't help myself.
    Plenty of work in a kitchen project - good luck and have fun. If you are like me you will be looking out the window alot.
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  3. #2413
    Gold Member SLHawkins's Avatar
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    John Deere 5403, International Harvester 584
    My day started with a drive out to Middletown to get a load of Ag-lime. Then back to the field to spread it. My Pop actually got quite a bit more seat time than me using the IH584 to pull the spreader. I followed up with the JD5403 and disc. I gotta give a shout out to my F450 though. It walked the walk coming up I-66 and Route 17 back to Fredericksburg. I apologize to the folks who got caught behind me. Even with the tarp, I was leaving quite a dust trail. It was a little windy and I did have the hamma down! 6 tons and the fuel mileage was still in the double digits!
    Hawk
    A lil bit country, and a whole lotta soul, wid a taste of hip hop flava on the side.
    JD 5403, , IH 584, NH 846 Baler, NH 492 Haybine, Woods E320 Batwing Rotary Cutter, Landpride RCR1572 Rotary Cutter, WR Long 72" OBRG, LandPride RB3596 Landscape Blade, '74 Diamond Reo Dump Truck; '70 F880, '94 Freightliner Classic, KNC 10 tooth Chisel Plow, New Holland Manure Spreader, 35' Texas Bragg Flatbed Gooseneck, Case 450 Track Loader, H-90CM Wheel Loader, '69 Kaiser Jeep M52A2 6x6
  4. #2414
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,001
    Rochester, MN
    Kubota BX2230
    Got 7 inches of snow over night. My Expedition would go through that easily of course, but my wife's car would not. So I took a 1/2 hour and cleared a path down the driveway before heading for work. Then I got another hour in after work finishing up. The rims on my BX were full of snow when I got done, so I just ran the toe of my boot around the inside of each rim before I put it into the garage. The last one, left rear, started to hiss and squirt out my fluid. So I got it in the garage quick and jacked it up and spun the valve stem to the top. It felt really wobbly, so I'm sure the rubber just gave out. I didn't even feel it when I "kicked" it. Guess I'll be calling around tomorrow to see if anybody can salvage the fluid and put in a new stem.
  5. #2415
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default
    Quote Originally Posted by RaydaKub View Post
    When I was a kid once I was kicking the snow out of the wheels on my dads tractor after he plowed and accidentally kicked the valve stem. Broke the thing half way off, let's just say I was not the favorite kid that day.
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  6. #2416
    Join Date
    Apr 2007
    Posts
    3,599
    NorthEastern, VT
    Quote Originally Posted by wmonroe View Post
    Somethimg about how you put that really made me chuckle.
    gg
  7. #2417
    Join Date
    Sep 2011
    Posts
    2,001
    Rochester, MN
    Kubota BX2230
    Default
    I used my air compressor to pump up the pressure (repeatedly) so that it would quirt the fluid out the valve stem. I tipped the tire over so that it would squirt into my oil pan. I captured about 10 gallons of the 11 in the tire. Then I took it to the tire shop and they put in a new valve stem and didn't even charge me for it. I've bought 5 sets of 4 tires there over the years, so I guess they want to keep customers happy. Then I took it home and reloaded the tire. BX tires are small enough that you can still handle them loaded, so I just let lay flat on the floor and let the fluid flow from the top of a ladder using my dehumidifier bucket. Lot's of burps later, it was ready to put back on. If I had a larger tire, I'd make sure to get the metal valve so there was a bigger hole to fill faster. 1/8" is TEDIOUS. But I'm back in business.
    Sent from my iPad using TractorByNet
  8. #2418
    Join Date
    Apr 2011
    Posts
    138
    West Gardiner, Maine
    Kubota BX 23
    Did about an hour yesterday pushing back snow banks in advance of predicted 10"+ storm on Wednesday.
  9. #2419
    Join Date
    Jul 2011
    Posts
    145
    JACKSON, MI
    McCormick CT28
    i pushed the 6" of slush off the driveway before it turned to frozen ruts over the next few days. then i got yelled at for getting a little dirt in the lawn............
  10. #2420
    Super Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar (For Sale), CS261, & FS190 + Echo CS400 & rusty old Ranger snowplow truck
    My neighbor recently sold his 60hp tractor (he is moving this summer and downsizing).
    So Yesterday I got 20-30 min of mucking out his run-in shed back dragging with the bucket.
    It was nice to be in the saddle again.
    Be well,
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, Titan 48" Pallet Forks, & more to come. & 2003 JD LX266 42" deck mower.
    Managing 51 Acres of Virginia hills with ponds & streams, Freshly replanted Loblolly!, riding trails, empty pasture, long gravel drive, garden, & yard.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
