Page 248 of 823 FirstFirst ... 148198238245246247248249250251258298348748 ... LastLast
Results 2,471 to 2,480 of 8225
  1. #2471
    Silver Member jonnyc1999's Avatar
    Join Date
    Nov 2010
    Posts
    177
    New Kent, VA
    Craftsman GT5000
    Default Re: TODAYS SEAT TIME
    This was from the storm the other day, but I thought you guys would get a kick out of my dad doing "Extreme snow plowing". He uses the plow for the initial clearing, then switches to the bucket and climbs up the bank to push the snow back. It seems to work pretty well and so far he hasn't "needed" a snowblower.
    TODAYS SEAT TIME-tractorwinter-jpg
    Yesterday I used my box blade to level the new gate opening into my yard. The gate is homemade, wooden, and 14' across. I think it "should" be perfect for my needs and I can't wait to get some gravel down on it.
  2. #2472
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Quote Originally Posted by jonnyc1999 View Post
    That's the way to Get er Done!!! Is his seat belt fastened??
  3. #2473
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,899
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Disked up about 10 acres of pasture for my Brother in Law after he finished spreading some fertilizer. You can see him on his NH way in the back ground pulling a drag over the area to smooth it out. We have been disking and dragging over sections of the pasture each year to smooth out the humps and holes a bit. This one is terraced from years previously when it must have been farmed by previous owners. I had to carry the disk to keep it from cutting too deep. It took me 2 1/2 hours running in Mid range 4th gear at 1500 RPM estimated speed about 6 mph. That was about the limit of speed due to the rough ground. Last week I disked up about the same amount in another section of pasture. So far I have burned about 3/8th of a tank of fuel (by gauge)on about 15 acres of pasture disking and working up the gardens with the disk.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-img_1207-jpg   TODAYS SEAT TIME-img_1208-jpg
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  4. #2474
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,091
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Thank you for the nice video of the chisel plowing. Would it be help to run a sub-soiler through that ground? I don't know your soil type.
    We did a 20 acre hayfild last year and decided to rip down 12" to 14" to loosen things up. It really pulled hard.
    May I be the kind of person my dogs think I am,
  5. #2475
    Gold Member SLHawkins's Avatar
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    John Deere 5403, International Harvester 584
    Quote Originally Posted by sixdogs View Post
    Thanks. The ground seems to drain pretty well. Eventhough we had received quite a bit of recent rain, the field was not muddy (though there were a few soft spots). I will see how the afalfa does this season and will consider running a subsoiler through the field at the end of the season. The field has not really had much traffic over it up until the last few years. And, even then, I cut some hay off it once a few years back and then have only bushhogged about 3 times a year for the last 2 years. Thanks for the recommend though. I will indeed consider it!
    Hawk
    A lil bit country, and a whole lotta soul, wid a taste of hip hop flava on the side.
    JD 5403, , IH 584, NH 846 Baler, NH 492 Haybine, Woods E320 Batwing Rotary Cutter, Landpride RCR1572 Rotary Cutter, WR Long 72" OBRG, LandPride RB3596 Landscape Blade, '74 Diamond Reo Dump Truck; '70 F880, '94 Freightliner Classic, KNC 10 tooth Chisel Plow, New Holland Manure Spreader, 35' Texas Bragg Flatbed Gooseneck, Case 450 Track Loader, H-90CM Wheel Loader, '69 Kaiser Jeep M52A2 6x6
  6. #2476
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Quote Originally Posted by SLHawkins View Post
    Hawk
    I thought alfalfa lasted five years or so between plantings?
  7. #2477
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    This'll will be the first time I have dealt with alfalfa and the first year it has been planted in this field. I'll see how it goes.
  8. #2478
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,001
    Rochester, MN
    Kubota BX2230
    I remember when my dad had alfalfa and we had to plow it up. Our "big" tractor was a Case 730 and pulled a 4-14 plow almost anywhere. The alfalfa was probably 5 years old, and to plow it up we had the model A JD chained up front and it was tough enough that both tractors paid attention. Good luck!
  9. #2479
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    Got in about another two hours on saturday afternoon running the disc over the field. Well, I shared some of that time with my Pop(I was behind the camera...). I will more than likely run the disk over it again before I put down the seed. It rained again today, so it'll probably be a week or two before I get back out there.
    John Deere 5403 and Bushhog 12' Disk Harrow - YouTube
    Hawk
  10. #2480
    Join Date
    Nov 2010
    Posts
    177
    New Kent, VA
    Craftsman GT5000
    Oh yeah, seatbelt fastened, hardhat on in case of falling branches. As dangerous as it looks, its a pretty effective way to push back the snowbanks! We don't get too many of those down in VA though..... ah, I miss New England winters
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
