Page 250 of 839 FirstFirst ... 150200240247248249250251252253260300350750 ... LastLast
Results 2,491 to 2,500 of 8389
  1. #2491
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Default Re: TODAYS SEAT TIME
    Quote Originally Posted by 94BULLITT View Post
    That is a awesome setup. I have heard the toolcat is great for snow removal.
    Will move dirt also. Grading piles from a dump truck with a 6' boxblade on a Berlon Tilt-Tach.
    TODAYS SEAT TIME-p2100029-jpg TODAYS SEAT TIME-p2100032-jpg TODAYS SEAT TIME-p2100035-jpg TODAYS SEAT TIME-p2100036-jpg
  2. #2492
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Quote Originally Posted by Xfaxman View Post
    I always drool when I see a toolcat A tilt-tach would be nice to have. Can you float the tilt-tach?
  3. #2493
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    Yep, push the joystick all the way forward and the boom floats. Digging angle is the curl function, tilt is aux hydraulics slide switch on the joystick.
    That is a 3 point to SSQA adapter on the boxblade
    TODAYS SEAT TIME-p2100038-jpg TODAYS SEAT TIME-p2100039-jpg TODAYS SEAT TIME-p2100041-jpg
  4. #2494
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I meant could you float the tilt-tach, the side to side movement.
  5. #2495
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    Nope, not without some modifications. There are times that would be handy. I will have to look at the possibility of making the tilt cylinder rod end pin removable.
    I did add a flow restrictor to fine tune the tilt. Guess I need a float valve too.
  6. #2496
    Gold Member kday64's Avatar
    Join Date
    Nov 2010
    Posts
    350
    South Eastern Connecticut
    Kubota BX2360
    Default
    Yesterday's seat time included loading the truck for the dump.
    The stumps where dug up using a 3.5t mini-ex. My little BX dropped them into the truck bed.
    CHEERS!
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-image-264483946-jpg   TODAYS SEAT TIME-image-931097846-jpg
    Kubota BX2360, 54" Fine Cut MMM, LA243 FEL, BX2789 Rear Snow Thrower
  7. #2497
    Join Date
    Nov 2010
    Posts
    350
    Kubota BX2360
    Default
    Okay, I want one. Can I get it in Orange?
  8. #2498
    Gold Member SLHawkins's Avatar
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    John Deere 5403, International Harvester 584
    Planted my hay seed on saturday. Now, I can sit back and watch it grow until it is time to cut, rake, and bale!
    Planting Alfalfa and Orchard Grass Seed April 2013 - YouTube
    Ok, I will use the time to fix stuff
    Hawk
    A lil bit country, and a whole lotta soul, wid a taste of hip hop flava on the side.
    JD 5403, , IH 584, NH 846 Baler, NH 492 Haybine, Woods E320 Batwing Rotary Cutter, Landpride RCR1572 Rotary Cutter, WR Long 72" OBRG, LandPride RB3596 Landscape Blade, '74 Diamond Reo Dump Truck; '70 F880, '94 Freightliner Classic, KNC 10 tooth Chisel Plow, New Holland Manure Spreader, 35' Texas Bragg Flatbed Gooseneck, Case 450 Track Loader, H-90CM Wheel Loader, '69 Kaiser Jeep M52A2 6x6
  9. #2499
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    Hawk
  10. #2500
    Join Date
    Nov 2007
    Posts
    435
    Northern Virginia
    Quote Originally Posted by Gordon Gould View Post
    Nice film of that tractor and disc working.
    Thanks!
    Hawk
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
