Page 262 of 782 FirstFirst ... 162212252259260261262263264265272312362762 ... LastLast
Results 2,611 to 2,620 of 7812
  1. #2611
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,679
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    Default
    Spent about 20 mins grinding down a 26" oak stump, a foot below the ground. It's been haunting me a while, but no more.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-image-4244462152-jpg
  2. #2612
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default Re: TODAYS SEAT TIME
    Quote Originally Posted by Piston View Post
    Does it take 2 remotes to run the grinder plus one for your HTL?
  3. #2613
    Join Date
    Sep 2008
    Posts
    3,679
    Lakes Region NH
    Roger, Yes it takes 2 remotes for the stumpgrinder, one for up/down, and one for side to side. I also have one for the top link and another for the side link, so 4 total.
    They sell a kit for the stumpgrinder though, for around $500 if I remember correctly, that enables you to use it with just a power beyond circuit, so I assume it's just a 2 spool valve kit that they sell, but I don't know as I've never looked into it.
  4. #2614
    Gold Member 8404's Avatar
    Join Date
    Sep 2009
    Posts
    261
    North Mississippi
    Cub Cadet 8404 or DK 40 Kioti
    yet another good day mowing. had to locate sewer line that hadnt been mowed in 6 years
    TODAYS SEAT TIME-007-jpg
    TODAYS SEAT TIME-010-jpg
    TODAYS SEAT TIME-011-jpg
    TODAYS SEAT TIME-008-jpg
    I ended up hitting one of the MANHOLES and breaking the hydraulic line to the powersteering, leaving most my hydraulic fluid on the ground and ontop of the manhole cover. The tractor is still out in the field tonight and probly tomarrow untill i can get the hydraulic cylinder repaired. at least it was a nice clear 95deg. to make it the most pleasent day ever.
  5. #2615
    Join Date
    Sep 2009
    Posts
    261
    North Mississippi
  6. #2616
    Join Date
    Sep 2008
    Posts
    3,679
    Lakes Region NH
    Default
    Did a little mowing job today, with some stumpgrinding and grading on the side.
    A friend of mine (parents actually) wanted a hand clearing the backyard some more. I loaded up the gear and spent 9 hours in the seat. First mowing, then cut down 5 trees, knocked over many small ones, ground down 7 good size stumps and a few small ones, then graded using the box blade to level off a few spots.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-image-3323192138-jpg   TODAYS SEAT TIME-image-2755376793-jpg   TODAYS SEAT TIME-image-3964805390-jpg   TODAYS SEAT TIME-image-2083884170-jpg   TODAYS SEAT TIME-image-3829708569-jpg
    TODAYS SEAT TIME-image-2949243229-jpg   TODAYS SEAT TIME-image-3281880787-jpg   TODAYS SEAT TIME-image-716480961-jpg
  7. #2617
    Super Member
    Join Date
    Dec 2007
    Posts
    9,730
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Impressive stump grinding photos. When I used to live with lots of trees it would have been the perfect tool.
    What's the price range that these things cost?
    May I be the kind of person my dogs think I am,
  8. #2618
    Join Date
    Sep 2008
    Posts
    3,679
    Lakes Region NH
    Quote Originally Posted by sixdogs View Post
    They're not cheap that's for sure. This particular model that I have, the Shaver SC50 is rated for 100hp tractor max, and 35hp minimum. It costs anywhere from 6500-7500 to buy new.
    I would never be able to justify the expense of one, but I stumbled across a good deal on this one and got it for a third of the price, plus it was barely used when I purchased it.
    I've made about half that back on stumpgrinding jobs since then.
  9. #2619
    Join Date
    Sep 2008
    Posts
    3,679
    Lakes Region NH
  10. #2620
    Veteran Member KenB2920's Avatar
    Join Date
    Sep 2011
    Posts
    1,164
    Almont, Mi
    Kubota L5240HSTC
    Default
    TODAYS SEAT TIME-image-1925461757-jpg
    TODAYS SEAT TIME-image-3277905461-jpg
    TODAYS SEAT TIME-image-3769722143-jpg
    TODAYS SEAT TIME-image-1480990913-jpg
    TODAYS SEAT TIME-image-2797040862-jpg
    TODAYS SEAT TIME-image-14044672-jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
