Page 275 of 838 FirstFirst ... 175225265272273274275276277278285325375775 ... LastLast
Results 2,741 to 2,750 of 8375
  1. #2741
    Super Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar (For Sale), CS261, & FS190 + Echo CS400 & rusty old Ranger snowplow truck
    Default Re: TODAYS SEAT TIME
    I GOT SOME SEAT TIME!!!!!
    First time in over 5 months!!!!
    I moved around the dirty bales of hay that I formerly used as the base layer for my horse hay storage to make some room for getting my attachments under cover.
    Well, I fired up the tractor (good Lord it was filthy) and dropped the stump grinder in one corner on a pallet, I piled the bucket, tooth bar, and ratchet rake outside the door. I went back up and hooked up the grapple again, and then the BushHog.
    I also hosed the cutter and tractor off because they were seriously filthy.
    My improvised PHD stand blew over a few months ago and dumped the PHD into a pile. It is the only thing still laying about outside needlessly (I've not figured out a place to put the bucket, tooth bar, and Ratchet Rake inside yet...)
    Regardless I got in at least an hour of ACTUAL SEAT TIME, and I loved every dirty second of it...
    More next weekend! WOO HOO!
    Be well,
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, Titan 48" Pallet Forks, & more to come. & 2003 JD LX266 42" deck mower.
    Managing 51 Acres of Virginia hills with ponds & streams, Freshly replanted Loblolly!, riding trails, empty pasture, long gravel drive, garden, & yard.
  2. #2742
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,990
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by xring100 View Post
    Xfax
    Don't take this the wrong way but I must admit That thing makes me giggle every time i see your ingenuity at work. Your methods are unique but seem to work well. I also like seeing your tellehandler in action also.
    Thanks, I understand, it is pretty funny looking. Hang on for more, going to put the brush fork on the TORO tomorrow.
    TODAYS SEAT TIME-p8110011-jpg TODAYS SEAT TIME-p8110013-jpg TODAYS SEAT TIME-p8110016-jpg
    Yep, the V417 is the best "tractor" that I have ever had!
    TODAYS SEAT TIME-p9290019-jpg TODAYS SEAT TIME-p9290024-jpg TODAYS SEAT TIME-p3180020-jpg
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
  3. #2743
    Member
    Join Date
    Sep 2011
    Posts
    36
    Festus, MO
    Kubota BX25
    Quote Originally Posted by clayj View Post
    BTW - if anyone's in the market for an SCUT with a mid-deck mower; RUN AWAY from the JD "drive over". The commercials are full of "stuff". The thing is a HUGE pain. Mine went back to the dealer for "Engineering Mods" three times before it would behave. There are only three reasons I'm still using it: Our lawn is too big for a push mower, I can't afford a "real" riding mower (in addition to my SCUT), yet, and I also can't afford a real "bushwacker" for the weeds on the rest of our 5 acres.
    Anyway, as soon as I can afford a riding mower and a 3-point bushwacker, the mid-deck is gonna get trashed. It works well enough once it's installed. Today I was wacking through weeds taller the tractor; but, getting it hooked up or disconnected, even AFTER all of the fixes, is a REAL pain. The problem is that the tolerances are REALLY tight and the "docking" components are still mostly cheap "pot metal" rather than steel - so, they break or bend and then nothing works (until, you bend stuff back into alignment).
    clayj -- I've had my BX25 with MMM for a couple years now. I'd say the first summer I was disappointed that I didn't buy the drive over instead. The commercial does make the JD driver over look desirable and if you don't have experience and if your dealer doesn't show you the correct way to mount the MMM on the kubota SCUTs, you will fight it until you figure out exactly how to mount it. Now it takes me more time to roll it under the tractor then it takes to hook it up. Until your post I still thought it was as simple as the commercial but thinking of what you said about the tolerances I can certainly understand how it may be a problem.
  4. #2744
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,626
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    Did my traditional Labor Day fall mowing under the old wild apple trees we have spread around our woods. We have a coulple dozen of them and I can get to about half with the mower. It is a little cumbersom using the sicklebar in small places but it is able to reach under pretty good. We have a ton of apples this year.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-mowappletrees1-jpg   TODAYS SEAT TIME-mowappletrees2-jpg
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  5. #2745
    Join Date
    Feb 2013
    Posts
    7,990
    Meridian, OK
    Moving a round pen, using the Gorilla Grapple on the V417
    TODAYS SEAT TIME-p9010002-jpg TODAYS SEAT TIME-p9010004-jpg TODAYS SEAT TIME-p9010006-jpg TODAYS SEAT TIME-p9010008-jpg
  6. #2746
    Platinum Member ljohnson778's Avatar
    Join Date
    Nov 2009
    Posts
    891
    Upstate NY
    New Holland T5070
    Default
    Quote Originally Posted by MossflowerWoods View Post
    Be well,
    David
    Good for you! Take it where, and when, you can get it!
    Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety.
    Benjamin Franklin
    The truth is incontrovertible. Malice may attack it, ignorance may deride it, but in the end, there it is.
    -Winston Churchill
  7. #2747
    Join Date
    Jun 2012
    Posts
    58
    Riner, VA
    Kubota M6040HD
    Default
    Today I did some pasture mowing at my in-laws. The local residents came out to inspect the big noisy orange thing that was invading their field.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-image-2287173680-jpg
  8. #2748
    Super Member Larro Darro's Avatar
    Join Date
    Jun 2013
    Posts
    6,262
    Altha Fl
    3930 Ford B1750 & B7500 Kubota
    I used the B7500 to bush hog last year's food plots. I mowed more briars on both sides this year. Last year the briars were so tall I wouldn't see the deer until they stepped into the food plot. Now I will be able to see them coming. Also cut some brush under one of our big oaks that had grown up with yaupon. Down here if you sit still for an hour, the yaupon will be growing between your toes.
    TODAYS SEAT TIME-007-jpgTODAYS SEAT TIME-011-jpgTODAYS SEAT TIME-013-jpg
  9. #2749
    Join Date
    Apr 2012
    Posts
    98
    Arab, AL
    Kubota M7040 cab
    Default
    Turned over some summer food plots today. Nice to get out and check some game cameras.
    Attached Thumbnails Attached Thumbnails TODAYS SEAT TIME-image-3338236229-jpg   TODAYS SEAT TIME-image-3822531918-jpg
  10. #2750
    Join Date
    Apr 2007
    Posts
    3,626
    NorthEastern, VT
    Nice buck there minner
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
