cartod
Moved a claw foot tub up to the new house m
I would take that ripper to a welding shop, remove that thin wall square tubing, replace with some 1/4" thick tubing and have them weld it up good with Full penetration weld on all 4 sides. OEM was poorly welded on the top with a concaved bead, sides don't look to have been welded at all. You should have broken the shank before breaking that weld.Today I had to run a shallow ditch for some water pipe for the lawn sprinkler system. I have a ripper that attaches to the three point hitch. Using that with my L4240 made the ditch digging both quick and fun. With that making me feel good, I thought I would use the ripper to pull up a few fairly good sized rocks in my back yard. The soil is still moist and I thought it would be a piece of cake. For the first few rocks, it was. I had the tractor in low range, two wheel drive. The tractor never lugged down, even on the last rock. However, the last rock won. I guess I'll re-weld (I only gas-weld) and put a stiffener on the back side. And, in the future, I guess I should use the FEL to dig the rocks out.
The picture of your dog didn't work, try again.New foreman on the job today was really dogging me , all he did was bark out orders all day
