jp2code
Tractor taking a nap?
Yea. The Motto of the story is ALWAYS have ROPS up and Seatbelt on!Must be a story that goes with that ???
Bucket was low, ballast present, being careful. Rear tire got in a small rut and was all she wrote. Hold on tight and tuck in. I was VERY lucky today.
Smoked like a freight train with motor on its side till it died. Even key wouldn't shut it off till it choked out.
Seatbelt was a little tricky getting released with 200lbs pulling on it. If this would have been in water a seat belt cutter would have been needed!
It must have ran on the motor oil. I never knew it could or would do that. Used a bigger tractor to turn back over, but wouldn't start for 30 min. The starter would start to turn a little and stop? Like vapor locked or something. When it finally started lots of blue smoke for a few min. After looking at another pic, my bucket wasn't as low as I had thought.Seems to be a lot packed into that short story. Glad you are OK. You think it was running on it's motor oil until it died ?? You said you finished the job so you must have it upright and running again. gg
I never realized that they would run on oil like that. Scary when you want it stopped. If this has went Omer the edge into basement it was a 9' drop with lots of long & short rebar sticking up. Enough to make you cringeYou were lucky in many ways here, first, your aok and not injured and second, a runaway diesel will run on its own oil until theres no more, and we all know what happens when they run with no oil. Glad its still running for you, the only way to stop a runnaway is to cut off its supply of air.
