cat fever
Elite Member
Drilled in a couple of railroad ties to make a calf loading area more secure. After fighting 6 calves (and loosing) I told my brother we need to improve his system. Next time will be much better. :thumbsup:
You should fight them one at a time. :laughing:Drilled in a couple of railroad ties to make a calf loading area more secure. After fighting 6 calves (and loosing) I told my brother we need to improve his system. Next time will be much better. :thumbsup:
I have been super busy doing tractor stuff.
I was finally able to clean up after the loggers so that my field can be hayed. It has branches and sticks probably 4 feet deep scattered over an acre where they had used the field as a logging yard and brought out and delimbed the trees. What a mess. I was not sure I could even clean it up with my Kubota, but did not want to spend money hauling in the big dozer for what would be a 20 minute job. In the end I was able to push some of the brush out of the way, then burn the rest. I also graded it, picked up sticks, and right before a night or rain, was able to seed it down.
In the meantime I have been working on one of my heavy haul roads. A logging truck skidded off one of my heavy haul roads this winter during an ice storm, so I stringed the entire road and set grade for any dips in the road. It was not much, just three inches lower then it should have been, but over 400 feet, a person can see the dip. I have been using my log trailer fitted with the dump body to haul gravel out of my pit to fill in the low spots. It has taken time, but looks a lot better.
When my log trailer is not hauling gravel, it has been loading logs for a friend who has been sawing lumber for his house.
Wow, and you do all that with six tractors? I just bet they are the prettiest models too...
Must be that pine air.
