#11 (permalink) |
Elite Member
I have to do about the same when I get around to painting my Case 1845 C. I was thinking about my engine hoist chained to the bed of my truck and give that a try and I only have to remove it once and replace it once.
__________________
Click here for my current weather Case 1845C with dirt bucket, forks, 3 point quick hitch on the front, 30'. boom, 6 & 1/2 foot disc harrow, 5 foot Howse RC, root and tree bucket and Grouser tracks and a Ford F-550 pick up,7.3 Turbo with Auto and a Crosley 25' X 8'.6" X 14 K D/O trailer. PDF files don't like me !! Making a F-550 Pick Up thread My Gallery My other Gallery Revielle video here Dear Eliot |
#12 (permalink) |
come on guys you are talking about twice a year with a cab that cant be that heavy anyhow. Yes I would drive under it, stand under it, sit under it. Now I'm not saying use a broken winch with a knotted nylon rope, but a good winch with a wire rope, I wouldnt think twice about it.
#14 (permalink) | |
Quote:
What i was thinking was some sort of pole thing,i could hang my chain falls from any one got pics? Dont fret the safety thing,my little bx can be pushed out from under it.GOOD THOUGHTS ON THE SAFETY !!! I need to make some sort of chain thing so i can lift all 4 corners equally at the same time. My garage has 10 ceilings ,no way is it high enough for the chain fall and to get the cab high enough ALAN
__________________
KUBOTA BX-23,LOADED AG TIRES,MECHANICAL THUMB,SALSCO CHIPPER,WOODS LRC60 LANDSCAPE RAKE WITH GAUGE WHEELS,,BUCKET FORKS,QUICK HITCH FOR 3 POINT HITCH,FRONT BUCKET-QUICK HITCH, FARM FORCE 6 FT 3POINT BLADE,MARKHAM TOOTHBAR,TRAILER HITCH FOR BACKHOE, HOMEMADE STEEL CAB,54 INCH PRONOVOST PUMA 3 POINT SNOW BLOWER,WITH HYDRAULIC CHUTE CONTROL |
#15 (permalink) |
Harbor Freight has a 1 ton telescoping gantry crane (lot#41188) on sale (<$530 this month) but its probably more than you'd need or want to spend for a one time use. Perhaps you could build something similar or get something like KennyD posted.
#16 (permalink) |
I know exactly what you need -- a great big trackhoe so you can lift up the cab, swing it to one side, and lower it.
Maybe that should be what I tell my wife.
__________________
40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple) |
#17 (permalink) | |
Quote:
Well if you don't have to sit under it then Ironhorse's boat winch idea may be the way to go. They are dirt cheap and easy to use. Just make sure you always get the ratchet locked in properly. It needs much less space than a chain block too. If you have the cable going up to a roller on the ceiling you will loose very little headroom and might even be able to use it in the garage. |
#18 (permalink) | |
Quote:
Mabey if i could get a 4 by 4 on top of 5 or 6 of them to distribute the weight![]()
__________________
#19 (permalink) |
If you use the existing trusses, use a piece of steel pipe to go across several of them to spread out the load. A piece of pipe thick/large enough to take the load without bending...
David from jax
__________________
A serious accident is one that money won't fix. |
#20 (permalink) | |
Quote:
__________________
2007 JD 5225 IOOS 540/540E, TNT, EH 3pt, 542 FEL with Skid Steer Quick Attach, 72" 4in1, 72" toothbar, 72" Grapple, Stump Bucket, 48" Forks, Hay Spike, Skid Steer to 3pt. adaptor, Hydraulic Adjustable Ballast Box, Cat. 2 Auger, 70" reversible tiller, hydraulic 3pt. boom, BushHog SQ600, Horiz/Vert 3pt. 4-way log splitter, Bomford B457 3' Boom Flail Mower, 7' landscape rake |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
