dan_d
- Joined
- Jun 9, 2008
- Messages
- 53
- Location
- Eastern ON, Canada
- Tractor
- Massey 275 + 236 loader, JohnDeere-Lanz 510 39HP 3cyl Diesel
Hi all,
First off, just like to say that I'm glad i found this site, tons of usefull info!
Anyways, I seem to have gotten myself into a much bigger project than I anticipated... When we moved into our house 4 years ago, there was a baler out in the field under a (very shredded) tarp, which I finally got the urge to pull out earlier this year. I've been tinkering with it and have managed to get one of the knotters working perfect every time, but the other one simply won't tie a knot. I've watched it and played around with a few things (replaced worn billhook, adjusted tucker finger) but everytime the billhook goes around, the "front" piece of twine gets missed. See http://www.dearaujo.net/pics/14T/IMG_6656.JPG I've also noticed something else rather peculiar with the intermittent gears which is also seen in that picture (and http://www.dearaujo.net/pics/14T/IMG_6654.JPG) where the offending billhook actually starts turning a little bit before the other! I find this rather odd since both intermittent gears are keyed so it's not like they could really be out of alignment (unless someone replaced one of them at some point and it wasn't exactly identical?) but that's the only thing i could see that could make one billhook do its little dance before the other! Am I missing a piece of the puzzle?
You can see the difference between the two billhooks in the following pics:
http://www.dearaujo.net/pics/14T/IMG_6646.JPG and http://www.dearaujo.net/pics/14T/IMG_6648.JPG
and a tiny bit later on the same knotting cycle...
http://www.dearaujo.net/pics/14T/IMG_6649.JPG and http://www.dearaujo.net/pics/14T/IMG_6650.JPG
I think the twine angle is the real culprit right now, since the twine is in its final position well before either billhook starts to turn... I thought I adjusted the tucker finger accodring to the manual, but maybe not? (the pic in the PDF (pg 28) is really dark, can't see what the "twine guide" is?) SHoudl the finger catch the twine right at the very tip, or further into the middle? The angle on the working knotter is always steeper, even before the tucker fingers grab it, so maybe there's something else i need to adjust? I checked the twine tension (by pulling out of the needle tip) and got ~13lbs on both sides, which is within spec...
Any insight would be hugely appreciated!
Thanks,
Dan
Thanks,
Dan
