Results 1 to 3 of 3
  1. #1
    Join Date
    Feb 2002
    Posts
    953
    Texas
    Mahindra 4110
    Default 4-wheeler\'s trick applied to tractors
    Here's a goofy little "Jeep" trick I applied to "tractoring" the other day -- Not sure if it has been posted here in the past, but thought I'd go ahead and post it anywho.
    I was using the box blade (low gears - VERY slow) and had just stopped making forward progress (rear dif locked, all 4 wheels still slowly turning though).
    Anyway, an old Jeeping trick for a "stuck" situation is to turn your steering wheel back and forth a couple of times while the wheels turn. I tried it and sure enough, works for tractors too. [img]/w3tcompact/icons/smile.gif[/img] The tractor tarted creeping forward once again and I was able to avoid even pushing in the clutch - much less throwing it in to reverse.
    Of course, this trick is useless unless you have a 4wd tractor. [img]/w3tcompact/icons/frown.gif[/img]
  2. #2
    Join Date
    Jan 2002
    Posts
    856
    South West Pa/Greene county
    Long/Landtrac360DTC
    Default Re: 4-wheeler\'s trick applied to tractors
    I've used that trick a time or 2 myself, both with my pick-up and my tractor. Great when you just need that little extra bit of traction.
  3. #3
    Gold Member
    Join Date
    Jan 2002
    Posts
    296
    tulsa ok
    kubota l3010hst/ford 601 workhorse
    great trick, I probably already do it naturally but maybe it will come to mind next time i get stuck
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
