#1 (permalink) |
New Member
No words just pictures,
Thought I'd show you guys how I am getting allong with plowing ! Post your comments !! Greets Carlos Silva ! Last edited by Carlos_Silva; 10-09-2008 at 06:19 PM. |
#2 (permalink) |
Gold Member
VEry nice. I like the tractor and the flip plow. The soil looks like dry clay--where are you located?
__________________
****** sixdogs "Make sure you sell all the puppies before your wife gets attached to them" |
#3 (permalink) |
Gold Member
i'm far from an expert but it looks pretty good!
one comment: your plows are actually backwards to mine - the moldboard turns to the left instead of to the right. i had to think about it for a minute, but it looks like you are doing it right only a mirror image of how i do it (my right wheels are in the previously dug furrows, your lefts are). one thing i do notice is that your plow rig seems to be level with the tractor. i have been taught that when the tractor is in the furrow on one side, the plows should be level with the ground making them actually lean to the opposite side when the tractor is level. you might experiment with this if its possible on your 3pt to see if you can get a better pair of furrows. right now it looks to me as if your right plowshare is not digging as deep as the left since the whole unit leans with the tractor. just a thought - others may disagree.... ;-) wish my garden was that big! no wait, i don't. too much work in july! amp
__________________
PM me with your email address to receive my Monthly Lawn & Garden Calender of Reminders. Helpful tips in your email each month. Kubota BX24 (loader, hoe, 60" belly); Ford 800 tractor; Scott's/Deere 42" mower; 5' and 6' rear blade; 54" Howse tiller; 20' 7,000 lb carhauler trailer; 2 other trailers; 5' dethatcher; 10" single bottom moldboard plow; middle buster plow; 600 lb roller; 3pt auger; front tire chains; Stihl and Honda small engine equip. Growing with you season by season. |
#5 (permalink) |
Elite Member
Wow, 29 HP with a double plow. I used my 30HP machine and it took work to use a big single bottom plow. It looks like your ground is very dry and was barren. When I plowed I was flooping over a big blanket of sod so the soil did not get torn up like yours looks.
I also agree that the plows should be adjusted to cut level when your tractor is in the furrow. I actually set up some blocks on a concrete surface and elevated the high side (left in the states) by the plow depth and then adjusted the plows to be flat and level front to back as well.
__________________
Kioti CK30HST, FEL w/toothbar, 60" RC, 60" BB, PJ 10k trailer. Weekend warrior hauling 50 miles each way. |
#6 (permalink) |
New Member
The kubota L2900 actually has 32 HP, and it pulls this 2x12" plow with ease !!
It has embarrased many european tractor brands here in Portugal that say their models have 35 HP ! :-) My old kubota L185 pulls a single furrow 12" Plow ! Greets Carlos Silva Last edited by Carlos_Silva; 10-10-2008 at 08:50 AM. |
#8 (permalink) | |
Gold Member
Quote:
__________________
Montana 4340C w/loader, AgroTrend FU78 rear snowblower with hydraulic shute rotation, Horst 48" pallet forks, 3pt. 2-bottom plow, 6ft. bush hog rotarty cutter, 3pt. Woods 7ft back blade, 3pt. cultivator, 5ft 3pt. york rake, 6ft. KK 3pt. Disk, 6' KKII tiller, JD1240 4-row planter, JD494 4-row planter. Future attachments: backhoe, grapple |
#9 (permalink) |
Gold Member
Carlos:
Thanks for the pictures. Will you next harrow to break up the clods and smooth the surface? What will you plant? That is pretty country, with the rolling hills. Is it typical of your rural areas? We would all like to know more about what you are doing. |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
