Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,713
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    Default 3 Pt hitch/PTO different categories?
    My father owns a case 275 tractor and it has a category 1 3 pt hitch. I don't really know what that means and what are the differences between them?? i think there are 3 different types right? Can you use category 2 implements with a cat 1 3-pt hitch? or vice versa? Are there any differences in the number of splines on the pto shaft?
    im pretty new at this tractor stuff and am having fun learning a lot from you guys.. thanks for all the info!
  2. #2
    Platinum Member rutwad's Avatar
    Join Date
    Jul 2006
    Posts
    828
    Alabama
    Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
    Default Re: 3 Pt hitch/PTO different categories?
    The Category of the 3 pt hitch is .............? Well, now you have got me thinking . OK, I am sure someone that knows will post.
    I think the Category of the hitch is related to size. For example, my friend's tractor has a Cat I and Cat II. The "balls" in the 3 pt. arms have 2 different size holes in each of them to accept different size pins. You simply rotate the ball to the size, either cat 1 or 2.
    The difference in PTO's is the most common 540 RPM and the 1000 RPM. It is not related to the 3 pt hitch. What I mean is you can have 540 RPM in Cat. 1,2,3, or 1000 RPM in all 3.
  3. #3
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    Basically the catergories is based on how much HP you have and the more HP you have, the larger the pins gonna be. To make this more confusing, if you have a cat 1 machine, you can also use cat 0 attachaments with sleeve adapters or cat 3 and use cat 2, cat 1 cat 0 but the cat 0 stuff probably will bend like tinfoil with all the HP the machine has.
    Category 0 3 Point Hitch
    This category is intended for tractors up to 20 Horsepower
    Toplink Pins are 5/8" diameter
    Lift Arm Pins are 5/8" diameter
    Category 1 3 Point Hitch<- - - Most common
    This category is intended for tractors 20 to 45 Horsepower
    Toplink Pins are 3/4" diameter
    Lift Arm Pins are 7/8" diameter
    Category 2 3 Point Hitch
    This category is intended for tractors 55-95 Horsepower
    Toplink Pins are 1" diameter
    Lift Arm Pins are 1 1/8" diameter
    Category 3 3 Point Hitch
    This category is for tractors above 95 Horsepower
    Toplink Pins are 1 1/4" diameter
    Lift Arm Pins are 1 7/16" diameter
  4. #4
    Join Date
    Jun 2006
    Posts
    839
    Northern Alabama
    2012 Kioti DK45SE, 1994 JD LX176
    The distance between the hitch arms as well as the mounting points on the implements also differ by class. See TractorData.com - Three-Point Hitch.
  5. #5
    Veteran Member kthompson's Avatar
    Join Date
    Sep 2008
    Posts
    2,029
    South Carolina
    Kubota M 6800; Kubota B 2710; Gator; Bushhog ZTR; Volvo Mini Excavator EC45, Ferris ZTR and John Deere 5525 tractor
    There is a difference between the PTO shafts between the 540 and 1000 RPM also. You might find an odd side 540 shaft out there on an old tractor.
    Jeremiah 2:11a "Has a nation changed its gods, Which are not gods?
  6. #6
    Join Date
    Oct 2006
    Posts
    755
    Thumb, Mich
    Re: PTO speed and splines. Yes, there are SAE standards for PTO shaft size and splines as well. 540 rpm takes a 1-3/8" 13 spline shaft. 1000 rpm is larger and more splines - right now I don't recall.
    The Opti-Mist
  7. #7
    Join Date
    Sep 2008
    Posts
    3,713
    Lakes Region NH
    Thanks for the info, this table from tractordata.com is really helpful, great drawing too for us "less informed" tractor people...
    Three-point hitch specifications
    Category Hitch pin size Lower hitch spacing Tractor drawbar power
    upper link lower links
    0 17 mm (5⁄8") 17 mm (5⁄8") 500 mm (20") <15 kW (<20 hp)
    1 19 mm (3⁄4") 22.4 mm (7⁄8") 718 mm (26") 15-35 kW (20-45 hp)
    2 25.5 mm (1") 28.7 mm (1 1⁄8") 870 mm (32") 30-75 kW (40-100 hp)
    3 31.75 mm (1 1⁄4") 37.4 mm (1 7⁄16") 1010 mm (38") 60-168 kW (80-225 hp)
    4 45mm (1 3⁄4") 51 mm (2") 1220 mm (46") 135-300 kW (180-400 hp)
    Does this mean that although you can get inserts for the hitch pins in order to use a lower category implement, you really can't use that implement because of the lower link arm spacing?
    For example if i have a category 2 3 pt hitch, but want to use a log splitter (or anything) that was made for a cat 1 hitch, it won't work because the link spacing on the cat 2 tractor would be 32" whereas the splitter is set up for link arms with 26" spacing?
  8. #8
    Join Date
    Sep 2008
    Posts
    3,713
    Lakes Region NH
    Sorry about that table in the above post, didn't paste like i was hoping, it came from the link that Greenwannabe posted....
  9. #9
    Join Date
    Sep 2008
    Posts
    3,713
    Lakes Region NH
    Quote Originally Posted by Opti-Mist View Post
    Finally found some more about this here.... TractorData.com - Power Take-Off Types
  10. #10
    Join Date
    Jan 2006
    Posts
    1,147
    Mass, Northshore, Merrimack Valley
    B6100DT
    Dan C.
    B6100DT, FEL, BH
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
