Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
  1. #11
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,107
    Ontario, NY
    Kubota BX24
    Default Re: Using tractor to move boat/trailer around property
    I did the same as what you did, drop a ball in the drawbar but i quickly discovered i didnt like the way it turns in the holes. the drawbar would flip before hooking up since the ball makes it top heavy and flips down. when moving trailer from forward to reverse it would feel it it hitting something. Adding a drawbar lock really helps but it wouldnt work on mine due to the way it was constructed on the BX.I assume that the B series has the full size 3 pt arms so a drawbar lock from TSC would work. To solve my dilemma, I basically welded a toplink post to bottom plate and used that bottom plate attached to drawbar. Now I am able to hook up the trailers and the drawbar is always level in up or down position, doesnt rotate, and holds trailer tongue securely. If you look on this TBN, there is a EZ trailer mover you could also use as well with your 2" hookups on your tractor.
    Attached Thumbnails Attached Thumbnails Using tractor to move boat/trailer around property-3-pt-welded-trailer-hitch.jpg
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Join Date
    Oct 2005
    Posts
    649
    PA
    NH TC40DA 2002
    I have also used 3-pt and wrapped light chain down to draw bar to prevent inadvertent lifting of the tongue if weight shifts to rear.
    2007 TC40DA, Supersteer, ANBO Grapple Rake with WR Long Joystick rocker control, Landpride 72" Box Scraper, 84" Rake, 72" Disc Harrow,72" Spring Tine Harrow, 72" Woods Rotary Cutter, Pallet Forks, 60 gallon Cropcare 3-pt sprayer, 72" 3-pt chain drag,Vicon 3-pt spreader
  4. #13
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,531
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    You will not have any problems moving around the trailer. I pull this boat all the time with my 28HP Jinma. The boat weighs 15,600# and is 38' long on the trailer from ball to back of the swim platform and is 10.5' wide.
    Here is another picture of one of my customers boats, a 31' long by 8.5' wide on the 3 point hitch. Its about 9,500#.
    Chris
    Attached Thumbnails Attached Thumbnails Using tractor to move boat/trailer around property-imag0104.jpg
    Attached Images Attached Images
  5. #14
    jmc
    jmc is online now
    Join Date
    Jul 2003
    Posts
    1,302
    SW Indiana
    Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
    There might be some confusion between the drawbar rigidly connected to the tractor frame, and a (perforated) "drawbar" that connects the lower links of the 3PH. The latter can't resist lifting forces, unless you restrain it like, FLINTLOCK did, or add yet another link connecting the upper and lower links.
    John
  6. #15
    Join Date
    Apr 2008
    Posts
    136
    Hunterdon Cnty, NJ
    Kubota B7800
    Wow! Thanks for all the responses guys!! Alot of good info here, need to sort through it all and figure out how to proceed.
    Here is a picture of the boat. I can't imagine it weighs more then 2000-3000lb.
    z0lt3c
    1979 John Deere 317 Garden Tractor
  7. #16
    Silver Member BXinNH's Avatar
    Join Date
    Aug 2008
    Posts
    139
    Southern NH
    Kubota BX24TLB
    I have a very similar boat. Before I got my BX I moved the boat around the driveway with a 16hp lawn tractor. It worked, but I don't think the tractor really liked it. Most any way you move the boat with your Kubota will be an improvement over how I did it.
    Matt.
    Kubota BX24 TLB, Loaded R4s, Wallenstein Thumb, BXpanded Forks
  8. #17
    Member
    Join Date
    Sep 2008
    Posts
    29
    NE Ohio
    Kubota BX 1850
    The carry all hitch from redland hill mfg. works very well and wasn't too expensive to purchase on E-bay. I have several different size hitches in all my trailers and log splitter. This set up comes set up with both a 1-7/8 and a 2" ball at the same time so I don't have to switch. I leave it on when I'm mowing as sort of a rear bumper in case I would back into anything.
  9. #18
    Gold Member
    Join Date
    Oct 2004
    Posts
    329
    Fayetteville, Georgia now should be GATC45
    New Holland TC-45D
    I made this with a QA plate I picked up from an auction. It works great. The pics show a gooseneck trailer, but I use it for my boat and utility trailer also. In most cases I'll have something on the back of the tractor for a counter balance. The ball mount rotates so I have all 3 ball sizes available. My tractor has R-4 tires so going across the yard is not an issue. I regret I never got it painted.
    Attached Thumbnails Attached Thumbnails Using tractor to move boat/trailer around property-dsc01398.jpg   Using tractor to move boat/trailer around property-dsc01399.jpg   Using tractor to move boat/trailer around property-dsc01401.jpg   Using tractor to move boat/trailer around property-dsc01403.jpg
    Mark
    New Holland TC-45D * Kubota M5400 * Bobcat T-190
  10. #19
    Join Date
    Apr 2008
    Posts
    136
    Hunterdon Cnty, NJ
    Kubota B7800
    Considering what a PIA it is to get my 3pt accessory removed, I'd rather not have to remove whichever tool I have back there to use the drawbar. It seems that alot of you have had success using your FEL with a receiver of some kind, since I have the Q/A adapter, some form of Q/A solution is what I have decided.
    I already have a Q/A adapter for my Tractor Supply 3pt carry-all to use in on the FEL. The carry-all has numerous bolt hole predrilled. My thought is to pickup the suggested TSC "Step Bumper Hitch Receiver," mount this to some stock, and bolt it down to the set of holes on the carry-all closest to tractor.
    Thanks,
    z0lt3c
  11. #20
    Join Date
    Jul 2004
    Posts
    1,554
    Bancroft, Ontario
    JD4300
    If you are going to use a ball on your FEL, make sure that the ball is sticking out about 12" in front of the base so you have room to approach the trailer from the side and slip the ball under the hitch. I laid a 24" piece of 2" angle across the front of my bucket, then extended another piece of 3" channel iron out towards the front with the ball in it. Welded the two together and fastened the channel to the bucket with a 3/4" bolt.(big enough to insert and tighten by hand). By keeping the bolt centered in the length of channel in the bucket it works to resist both up and down loads on it, the angle handles any side loading. With the ball at the very end of the channel you can also lift a trailer tonque high enough to dump a load of wood.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
