Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
When I worked at the airport we used to have to drive ground rods all over the place for grounding airplanes when fueling. We had air brakes on the fuel trucks, and that meant an air tank. We hooked up a length of air hose to the tank, then used an air chisel with a cupped bit to drive 10' ground rod down through the intersections of concrete joints. Those things would zip right down in just a minute or so. So, I wonder if that type of thing would work with T posts? Put that hand operated post pounder in a couple of eye loops on the side of the FEL bucket, weld an air chisel bit to the top of it, attach the air chisel, then drive up to the posts, put the pounder over the T post and bzzzzt vibrate it down.
Anyhow, don't want to hi-jack the thread.
Interesting idea... I bet you could make one from a jack hammer! air or electric.
soundguy
