Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Platinum Member hwp's Avatar
    Join Date
    Dec 2001
    Posts
    643
    St. Catharines, Ontario, CANADA
    Kubota F2400
    Default Sharpening and Balancing Mower Blades
    I have a kubota F2400 with a three blade RC60 mower deck. What is the best way of sharpening and balancing the mower blades. In the past I sharpened them using a bench grinder but lately I have been using an angle grinder. Is one way better than the other? Or are there even better ways? I have read somewhere that the blades should have a flattened surface of 1/64" on the leading edge. How do you do this?
    I check the balance of the blades by putting them on a bolt and spinning them by hand in the vertical plane? Should they be checked in the vertical or horizontal plane? Should the check be static or dynamic?
  2. #2
    Join Date
    Apr 2002
    Posts
    632
    Indiana
    New BX2200 4-3-02 (traded 6-08) new B2620 06-08
    Default Re: Sharpening and Balancing Mower Blades
    I use a 4" angle grinder with a flimsy disc with the blade clamped in a vice... The flimsy disc kind of follows the original edge better than a hard stone... I use a nail to check balance. I have a blade level but prefer the nail. If you put the blade on the nail and it won't stay horizontal then it's not level.. kind of simple way to check them....
  3. #3
    Platinum Member Steelfan's Avatar
    Join Date
    Dec 2001
    Posts
    648
    Central PA
    New Holland TC21D
    Hoosier_Daddy, Just a bit more detail for us if you could? I'm new to this, but I'd really like to sharpen my blades myself. [img]/w3tcompact/icons/blush.gif[/img] How do you use the nail? I'd be grateful for the help. Kent
  4. #4
    Veteran Member Will_C's Avatar
    Join Date
    May 2002
    Posts
    1,679
    Upstate N.Y.
    Kubota B 2620, Toro 52" and 60" ZTRs, Kubota RTV 900
    Along with Kent, I would like any input people have on blade sharpening tips. I now do my own, but I sure would like to hear any advice about improving my skills. If this has been discussed before, maybe someone could help by pointing out the thread.
    Thanks, Will.
  5. #5
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,768
    Texas
    I've sharpened mower blades with both a 6" bench grinder and a 4.5" angle grinder (blade held in a vise when using the angle grinder). Either one works pretty well. It may depend on the design and shape of the blade. Because many of them are turned up on the back side to "lift" the grass, they can be a little awkward to slide straight across the guide on the bench grinder. I suppose the most important thing is to try to grind a little at a time to avoid getting the blade too hot and ruining the temper (and since I sharpen them pretty sharp, I've burned the edge of a few[img]/w3tcompact/icons/frown.gif[/img]).
    As for balance, I do about the same thing as Hoosier Daddy. I use a very small round shaft screwdriver, no bigger probably than the nail he uses. I simply stick the screwdriver shaft through the bolt hole in the center of the blade and holding the screwdriver horizontally, and the blade horizontally, see if the blade stays horizontal when I turn loose. If one end droops, it must be heavy and I grind a little more off that end.
    As for the 1/64" flat leading edge, I don't worry about it on lawnmower blades. If you want to grind off a little flat edge, that's fine, or just don't grind it down really sharp to start with. That flat leading edge just won't get dinged up as quickly or easily as a really sharp edge, but if all you're cutting is grass and weeds, I kinda like a sharp edge. Brush hog (rotary cutter) blades are another matter, of course.
  6. #6
    Join Date
    Nov 2001
    Posts
    311
    Vermilion County, IL
    2000 B7500HSD Kubota, 2 Case ingersol 448 tractors
    I just sharpened the blades for 3 point mower. I picked up a 4" flap grinder wheel at Harbour Freight. I have sharpened my own blades for a long time. This was the quickest and slickest that I have ever done it.
  7. #7
    Join Date
    Apr 2002
    Posts
    632
    Indiana
    Bird uses a screwdriver and that would work.. I just pound a finish nail into the work bench and hang the blade on it. If the blades have bent angles on them you may need a little longer nail.... Hold the blade horizontal and let go..... The heavy end gets more ground off.... I like the flexible wheel with the angle grinder because it doesn't seem to heat up the blade as fast. If the blade starts to change color, back off and let it cool. You could take the temper out of the steel if it gets too hot....
  8. #8
    Join Date
    Dec 2001
    Posts
    648
    Central PA
    New Holland TC21D
    Thanks Bird, jhburke, & Hoosier_Daddy. I'm glad you, gentlemen replied. I was just a bit unclear about balancing the blades. And I'm assuming the best tool is a right angle grinder? Also the Harbour Freight catalog is very comfortable in my hands. I've ordered from them for years. Thanks Again Kent
  9. #9
    Join Date
    Nov 2000
    Posts
    609
    Chillicothe Mo.
    L4610,BX2200,ZD28F
    Steelfan,I use a very Hi-Tech blade balancing system myself.Couple of pieces of plastic that will cost you close to 2 bucks at about any Hardware Store.
    The sides of the cone are graduated to accept about any sized blade,it will quickly show you which side of the blade needs to be fine tuned.
    Before sharpening I always try to take the grass "build-up" off the blades with a bench grinder equipped with a wire brush.Also use a hand file too really put that finished edge on the blades after hitting them with a 4" hand held.
    Attached Images Attached Images
  10. #10
    Join Date
    Nov 2000
    Posts
    609
    Chillicothe Mo.
    L4610,BX2200,ZD28F
    Another look...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
