Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2002
    Posts
    28
    Morgantown, PA
    Kubota/ BX2200
    Default BX2200 rear lighting
    I have viewed alot of threads on B7500, etc rear work lights. I was wondering if anybody has done anything different in mounting rear lights on a BX2200? This is all new to me so I want to be smart in what light(s) I use and how I mount them. Does anybody know where to purchase lights that have a built in switch? I think I would like to use such lights so as not to have to drill and mount a switch on the dash area to operate rear facing lights. Thank you in advance for your feedback.
  2. #2
    Join Date
    Apr 2002
    Posts
    102
    Northeast OH
    TC33D
    Default Re: BX2200 rear lighting
    New Holland shows rear work lights with a switch. I would think you could pick them up at any NH dealer.
  3. #3
    Join Date
    Nov 2000
    Posts
    1,720
    Columbia county NY
    87 Ingersoll 444, 84 Ingersoll224/'44 GreavlyL/60'sGreavlyL/49 Ford 8N
    You should be able to drill, and install a switch in most lights. Just make sure there is room in the housing.
  4. #4
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,384
    Lancaster County, PA
    Kubota L3200, Ford 1210
    The rectangular lights I have worked with were available in "spot", "trapezoid" and "flood" patterns. With the close distances I wanted to illuminate, the flood pattern worked best for me. The light pattern of the trapezoid didn't spread at a wide enough angle to work well in my application. That same light would be fine on one of my in-law's "real" tractors where you need to climb a ladder to get to the seat, and the light is 8' off the ground.
    I also added a pair of the floods facing front on my tractor. The factory headlights are a poor source of light to actually work by. Mine are on the FEL bracket and are angled out slightly. They provide almost 180 of light....................chim
  5. #5
    Gold Member
    Join Date
    Aug 2001
    Posts
    289
    N WI
    Kubota BX2200
    Tazbota,
    Since I don't operate on the road I bought a SMV mount and installed a light and switch on that with a coiled cord connected to the under seat wires. It works well as it is removable and can be used as a short extension light. I can also remove it and replace the SMV if need be.
    Good luck,
    Michael
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
