Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1
    Join Date
    Jan 2002
    Posts
    1,561
    South East Michigan
    New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
    Default Gouged My Tire !
    Backed my tractor into my backblade and sliced the rear tire with the 3/8 thick steel upper mount. [img]/w3tcompact/icons/sad.gif[/img] The tires are Titan 13.6x16 Turf tires. There is a groove scraped out of my tire about 3/8 wide and about 3/16 deep. [img]/w3tcompact/icons/sad.gif[/img] The tire did not puncture all the way through but I am concerned because this is only a 4ply tire. The gouge is in the sidewall and is about 3 inches long. [img]/w3tcompact/icons/sad.gif[/img] Should I put some silicone, glue, RTV, or permatex in the void ?
  2. #2
    Elite Member
    Join Date
    Feb 2002
    Posts
    4,383
    Janesville, Wisconsin
    None -yet. Until then FunBuggy (EZ-Go) will have to do!
    Default Re: Gouged My Tire !
    Jerry,
    Sorry to hear about your tire's BooBoo! [img]/w3tcompact/icons/sad.gif[/img]
    When I was in high school, I worked for a tire dealership that specialized in industrial and commercial tires. I don't ever remember "filling" in gouges in the sidewalls. And like I said, the tires we dealt with were used very hard. So I wouldn't think you'd need to worry about it.
    Having said that, and recognizing that my days at the tire service were just a few years back, there have been a few improvements in tire repairing since then. You might want to call a tire dealer, just for peace of mind, or to get the best advice on how to take care of it.
  3. #3
    Join Date
    Jan 2002
    Posts
    166
    Louisburg NC
    02 Kubota L-4610 HST w/4in1 bucket & R-4s
    I think the only peaqce of mind you'll have is a new tire. I don't think the "fill a hole" technology is in place as of yet. I know these tire aren't cheap though, you may want to ride it out? Good luck, keep us posted.
  4. #4
    Join Date
    Jun 2002
    Posts
    204
    Aiken, SC
    Kubota 3710, 1970 Leland 384
    You could also take and have the tire filled with foam. Then you can run it till it falls off.
    Don
  5. #5
    Super Member JerryG's Avatar
    Join Date
    Apr 2000
    Posts
    7,090
    Northwest Arkansas
    MF 1440-4 PowerShuttle
    Jerry,
    Take it off and take it to your tire shop. Tell them you want a over size boot for the damaged area. You will never have to worry about it again.
  6. #6
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    35,062
    Texas
    The "boot" that the other Jerry mentioned is only good for patching the inside of a tire and you say you gouged yours on the outside. Can you see any of the cords exposed or broken? Now I'm not claiming to be a tire expert, but if it were me and no cords broken, I'd ignore it and run it. On the other hand, if the cords are broken, I'd be shopping for a tire. Of course, if the impact broke cords on the inside, then Jerry's "boot" might work. I've used lots of them (even made some homemade ones out of old inner tubes), but like most patches, they work best in the tread area and I wouldn't count on one lasting long for a sidewall. As far as putting silicone, RTV, or whatever in the gouge, I don't think it would hurt a thing. The trouble is that I also don't think it would do a bit of good either.
  7. #7
    Join Date
    Jul 2001
    Posts
    1,806
    Houston, TX.
    2001 TN65, 1951 8N Ford
    Run it. Industrial tires such as these ( I know you have turfs, they're still an "industrial" tire) get divots and other damage all the time. If it blows out, stick a tube in it with a boot over the inside of the hole just to keep stuff out. I would watch my speed, though. It might be dangerous over 70 m.p.h..
  8. #8
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,074
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    For what its worth, my old ford 8n has up to 3/8" of rubber missing in lots of places, especially the sidewall.. but holds air very well.
    Soundguy
  9. #9
    Join Date
    Jan 2002
    Posts
    1,561
    South East Michigan
    For what it's worth, here's some pictures from my new digital camera. I agree Bird, some goop would only have cosmetic effects.
    Attached Images Attached Images
  10. #10
    Join Date
    Jan 2002
    Posts
    1,561
    South East Michigan
    I know I'm probably overreacting, but it's so young to suffer such indignity.
    [img]/w3tcompact/icons/laugh.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
