Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Join Date
    Jan 2002
    Posts
    1,561
    South East Michigan
    New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
    Default Implement Dollies
    No, not that kind of 'Dolly'
    I bought these from Northern Equipment. They are expensive ($59 for a set of three) but can hold 500lbs each and glide on my smooth concrete floor like 'Butter'.
    Attached Images Attached Images
  2. #2
    Join Date
    Jan 2002
    Posts
    1,561
    South East Michigan
    Default Re: Implement Dollies
    Makes for easy implement hook-up and storage. [img]/w3tcompact/icons/grin.gif[/img]
  3. #3
    Join Date
    Jan 2002
    Posts
    1,561
    South East Michigan
    Oh Yes !, Another one !
  4. #4
    Join Date
    Jan 2002
    Posts
    1,561
    South East Michigan
    [img]/w3tcompact/icons/eyes.gif[/img]
    Go ahead........, ask me why there is two sets of lowers pins and two sets of upper pins.
  5. #5
    Super Member Inspector507's Avatar
    Join Date
    Mar 2002
    Posts
    5,908
    Central Ohio
    Jerry,
    I bought the ones similar to what Harbor Freight has that are dished in the middle for a vehicle tire. I know, Harbor Freight, I know [img]/w3tcompact/icons/grin.gif[/img]. I bought 2 for $39.95. Supposed to handle a heck of a lot of weight. I've used them to move various things in the garage but never a car, tractor or implement.......yet.
  6. #6
    Join Date
    Apr 2002
    Posts
    874
    Monroe,Washington
    New holland TC29-9x3 Woods 1012 FEL, Woods, 7500 Backhoe / Kubota L345DT 4WD, Kub FEL, Kub Backhoe
    Ok why are there two sets of pins? Let me go one better, why are the implements Farmall red instead of New Holland Blue?
  7. #7
    Join Date
    Jan 2002
    Posts
    1,561
    South East Michigan
    They're red because I bought them at the Massey Dealer. [img]/w3tcompact/icons/blush.gif[/img]
    The two sets of pins allow me to attach the rake at a lower point and get a higher range of motion. With the stock location I can only lift the rake about two inches off the ground. The top link angle that is required for gauge wheel operation creates this range of motion problem. So, I welded on some additional mounting locations. Of course, I can't turn the rake 180 degrees now, but never did anyway. [img]/w3tcompact/icons/smile.gif[/img]
  8. #8
    Join Date
    Feb 2002
    Posts
    163
    Deep Creek Lake Maryland
    None In decision Mode
    I pick up casters wheels at auctions and flea markets every chance I get. You can pick them up for .50 or a buck or two, sometimes a little more depending on the size. You would be amazed at the heavy duty wheels I've picked up.
    Even if I only get one or two they just get tossed in a five gallon bucket until I can pick up something that matches. Practically everything in my basement and garage is on wheels usually with an angle iron or plywood frame. Welders, sandblast cabinet, free standing shelving, even five and fifteen gallon buckets. I have to say it's one of the handiest things I've done for myself. Makes clean up and reorganizing a breeze.
  9. #9
    Veteran Member Carl_NH's Avatar
    Join Date
    Apr 2002
    Posts
    2,181
    Coastal NH
    01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
    Jerry,
    Nice clean concrete and all implements in order.. I remember my shop/barn looked like that for the first few days then my tractor and tools moved in..
    Carl
  10. #10
    Join Date
    Jun 2002
    Posts
    204
    Aiken, SC
    Kubota 3710, 1970 Leland 384
    Sounds like a man that has discovered the wheel.
    Some day when I get some concrete down I might even buy some wheels. Those small ones don't work good in dirt.
    Don
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
