Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
  1. #11
    Join Date
    Nov 2003
    Posts
    148
    Western Wisconsin
    Default Re: Cleaning mower deck
    I found it impossible to keep the mower deck underside coated with anything. When mowing, the blades pick up and propel rocks, sand, branches, you-name-it against the surface directly above them. Under the onslaught of regular mowings, I don't think anything can hold up for very long. Unfortunately, the surface that gets pounded is where the grass clippings, dirt, and wetness build up and harden to a cement-like consistency. So, I think we're fated to scrap, blast, chop, hack, spray, soak, and scour our beloved mower -- ****, we can't just let it get all crusty, can we?
    jim
  2. #12
    Elite Member
    Join Date
    Mar 2005
    Posts
    2,762
    Bedford, VA
    John Deere 2320
    After recoating the underside several times I am thinking the same thing - at least in a DIY coating..
    I wonder if anyone has used a ceramic type coating?
    Brian
    Quote Originally Posted by RedHawkRidge View Post
    jim
    Bedford, VA
    2320 w/ 62D MMM, 200CX FEL, Pats EZ Change, LX4 Cutter
    Co-owner (with my father) of John Deere 790, 30 HP, 4x4, 513 cutter, 70 FEL
    2012 Nissan Xterra Pro-4x
  3. #13
    Platinum Member prosperity's Avatar
    Join Date
    Aug 2000
    Posts
    690
    North Central Pennsylvania
    JD 2520
    I don't want to sound like a smart-*****...but...
    Having a regular deck cleaning routine will avoid all this.
    I am a little over-the-top with stuff like this, but I will never put my machines away leaving any wet grass under the deck.
    If I mow when the grass is wet (usually quite often as I have an area always in the shade), I will clean the underside of the deck before I put it away. If you do it right away, it all comes off very easily.
    If done right away - I have a set of ramps nearby - drive the tractor up on the ramps, and just a water hose will wash everything off.
    If I happen to let it go a bit, then a plastic paint scraper and/or pressure wash will easily take care of it.
    Leaving the underside with caked on wet grass is just inviting rust in my opinion - I certainly don't want to let my $2500 deck rust out.
  4. #14
    Elite Member
    Join Date
    Mar 2005
    Posts
    2,762
    Bedford, VA
    John Deere 2320
    Point well taken.. I had cleaned (and recoated it with slip plate) late in the summer, but I had used it before I put it away and just never got around to cleaning it..
    Since I dont take the deck of during mowing season, I will try the ramp trick to see if that will help keep it from getting totally caked on
    Brian
    Quote Originally Posted by prosperity View Post
    Bedford, VA
  5. #15
    Member Water Boy's Avatar
    Join Date
    Mar 2010
    Posts
    49
    Michigan
    Kubota B2320
    I find that a good coat of car wax on the underside of the deck makes it easier to clean. I do it for the FEL and shovels for snow removal as well.
    WB
    Kubota B 2320 With BH and FEL
  6. #16
    Gold Member
    Join Date
    Dec 2003
    Posts
    284
    Southern NH
    Kubota B7610
    The flat end of a 3' pry bar, used like a scraper, takes off anything caked on like it's barely there.
  7. #17
    Gold Member Whitey's Avatar
    Join Date
    Dec 2007
    Posts
    254
    Slippery Rock, Pennsylvania
    Kabota B21 TLB
    I had our JD 425 mower deck repainted a few years back......blasted, primed and painted JD yellow, the underside, undercoated with Rhino coat without the aggregate, smooth rubber underside, only have to clean it once a month instead of every time.......and wet grass....no problem.
    John Deere 425 AWS / 54" MMM / 54" Sno Blade / Kubota B21 TLB
    A patient man has great understanding; but a quick tempered man displays folly.
  8. #18
    New Member
    Join Date
    Feb 2010
    Posts
    3
    I was just wondering about doing an undercoating for the bed of a pickup on the bottom of my mower. I might stand my mower up this spring and sand down the underside real good and brush on some undercoating and see how it does. There's no way I'm putting paint back under this thing. How does your Rhino hold up to the mowing?
  9. #19
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,933
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    I don't go to extra effort to clean the underside of the deck. It stays quite clean with small sticks and hickory nut shucks . But not mowing when the grass is wet helps the best.
    Have never heard of any product that will work to keep it clean...where it takes the place of regular cleaning before putting it away.
    When putting mine away, I first blow the tractor and deck off with air, and avoid washing it down with water except on a rare "wash day". And store the tractor/mower inside to avoid rust.
  10. #20
    Elite Member
    Join Date
    Mar 2005
    Posts
    2,762
    Bedford, VA
    John Deere 2320
    I went back out today to finish cleaning the deck.. After hitting it with a wire brush on a drill I realized that 90% of the deck was still covered with Slip Plate.. I thought the silver i was seeing was bare metal, but it was the slip plate..
    There are a few places that dont seem to hold the slip plate... I am going to recoat it this weekend to see if I can get a better coverage..
    I need to make a better effort of cleaning it off more regularly though..
    Brian
    Bedford, VA
Similar Threads
  1. Mowing Removing a mower deck from BX23
    By HockeyFan in forum Kubota Owning/Operating
    Last Post: 06-24-2012, 06:32 PM
  2. Mowing mower deck cleaning
    By varmint in forum Owning/Operating
    Last Post: 06-24-2012, 04:43 AM
  3. Mowing BX-23 Mower Deck Cart
    By willjack in forum Kubota Owning/Operating
    Last Post: 01-08-2007, 09:18 PM
  4. Mowing cleaning underside of BX2200 mower deck
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 06-22-2003, 11:40 PM
  5. Mowing Cleaning Mower Deck
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 03-24-2003, 10:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
