Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Gold Member Kubota Tee's Avatar
    Join Date
    Dec 2009
    Posts
    267
    Hudsonville, MI
    Kubota L3540HST-3
    Default Best way to learn = do!
    I purchased my new kubota L3540 back in January and didn't get much of a chance to use it until the snow melted. Sure, I played with it in the snow a bit, but the real work was planned to begin when the weather turned a bit warmer.
    Now that the weather is nice, I have been taking full advantage of this new machine to install a 300' driveway. This involved first scraping all the top soil off and piling it up. I then replaced the top soil with fill (mostly sand mixture) and brought it up to the desired grade level. I probably moved 500 yards of fill material to create the grade that was needed. I then started the process of moving the road gravel off of an existing driveway onto the new driveway. This involved a lot of scraping, piling and FEL work to move 6" of road gravel for the 12' wide x 300' long drive.
    I did end up running short with the road gravel since the old driveway was straight and new one is curved, so I had about 30ton of crushed concrete brought out and dumped evenly on the whole length. Didn't take too much grading work after that to get it just right.
    I am now in the process of balancing the site on both sides of the new drive which involves a lot of grading and FEL work. In some areas, there is a 2' grade difference between the new driveway and old grade. I have pictures that I will be posting soon so you can see the magnitude of the work that has been done. I have about 40+ hours into this project. I probably could have hired this project out and have it completed in 1 day, but I couldn't image a better way to learn all the operations of my new tractor and the finer points of using the box blade and FEL bucket.
    Thomas (aka Kubota Tee)
    Kubota L3540 with LA724 FEL.,HD Bucket with bolt on cutting edge, Custom FEL Forks, Taylor Way 7' box blade, 6' gill rake, Custom Tree Scoop, 6' Woods finish mower, custom FEL attached snow plow.
    Toro Z Master 6000 with 60" mower deck
  2. #2
    Elite Member Mousefield's Avatar
    Join Date
    Aug 2008
    Posts
    2,618
    Qualicum Beach on Vancouver Island, BC. Canada
    Sold 2008 CK35 HST
    Default Re: Best way to learn = do!
    Looking forward to the pics.
  3. #3
    Platinum Member Army grunt's Avatar
    Join Date
    Dec 2009
    Posts
    792
    Georga
    TC 30 Newholland
    Good on ya. I do a lot of stuff an learn by doing is, an has always been my way.
    I always feel better after.
    Army Grunt
    "Be who you are, say what you will, those that matter wont mind, those that mind don't matter".
  4. #4
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,799
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Yep, the best way to learn is doing it; been operating them for years and still learning.
    "In theory, there is no difference between theory and practice. But in practice, there is." - Yogi Berra
  5. #5
    Join Date
    Mar 2010
    Posts
    715
    University of hard knooks,best education there isDave
  6. #6
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    16,541
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    Hands on still the best way..give it heck and enjoy.
  7. #7
    Veteran Member JDGreenGrass's Avatar
    Join Date
    Oct 2009
    Posts
    1,578
    Maine
    John Deere 770
    Looking forward to seeing some pictures.
    I just moved 12yds. of loam with my jd770. Rebuilt a portion of my lawn and filled in where some stumps were chipped out. I enjoy hand raking but, with a tractor and a rake I thought to myself....there's got to be an easier way.
    Hooked up the rake and gained experience as I went along. Finished product came out beautiful.
    I might add that I have used the rear blade for grading and that is a great tool, as well.
    Good luck with your project.
    JD770 '92 4x4 SMC FEL JD Ballast Box 6' CountyLine Back Blade 6' CountyLine Rake CountyLine CarryAll
    64" Frontier Snowblower
    Favorite Color....Green
    The sky was yellow and the sun was blue.
  8. #8
    Veteran Member pitt_md's Avatar
    Join Date
    Apr 2008
    Posts
    1,030
    Pine Island, MN
    Kubota MX5000
    When it come to tractors and horses do your learning carefully, either will kill you quickly if not paying attention.
  9. #9
    Join Date
    Dec 2009
    Posts
    267
    Hudsonville, MI
    Kubota L3540HST-3
    Thanks everyone for the encouragement! Here are the pics that I promised. The first ones are the before pictures when I first got started. The previous drive was a straight shot from the cul-de-sac up to the house. The new one is curved. The first step was to remove the top soil.
    Attached Thumbnails Attached Thumbnails Best way to learn = do!-img_1314-jpg   Best way to learn = do!-img_1315-jpg
  10. #10
    Join Date
    Dec 2009
    Posts
    267
    Hudsonville, MI
    Kubota L3540HST-3
    The next step was to build up the base with fill (mostly sand) to make a nice gentle slope from the house down the cul-de-sac. Then I moved the road gravel from the old driveway to the new one and finally had some crushed concrete spread on top.
    Attached Thumbnails Attached Thumbnails Best way to learn = do!-img_1570-jpg   Best way to learn = do!-img_1571-jpg   Best way to learn = do!-img_1569-jpg   Best way to learn = do!-img_1572-jpg
Similar Threads
  1. Welding - I want to learn ..need advice.
    By brin in forum Welding
    Last Post: 01-10-2010, 01:09 PM
  2. Lots to learn
    By ElmBrook in forum New Member Introductions
    Last Post: 11-22-2009, 10:46 AM
  3. Small businesses - learn from my mistake
    By metalcaster in forum Related Topics
    Last Post: 07-15-2008, 09:06 AM
  4. Replies: 17
    Last Post: 07-21-2005, 01:52 PM
  5. Now I have to learn to weld!
    By slydog in forum Build-It Yourself
    Last Post: 10-28-2004, 10:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
