kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,910
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
Congrats on the tractor and good luck with it. Take things easy with it and learn as you go along. One point I will make with all the other excellent advice given is that since your fuel gauge doesn't work, (and assuming it has a diesel engine) DO NOT let it run out of diesel fuel. Keep a close check on the fuel level. If it runs out, you will have to bleed all the lines to get the fuel system and get all the air out of them. Not the easiest thing to do for someone new at it. Then again, you may already have experience with all that??
